Question about Philips 60PP9352 60" Rear Projection Television
Warped Picture, Separated colors
My Philips 60" rear projection TV has a problem with the green CRT. At first, I had separated colors at the top and bottom of the screen. Then I did a convergence alignment. The colors did align, however the green CRT will not align straight. When the green grid is on the screen, the top middle warps down to the center and the bottom middle warps up to the center. I CANNOT adjust the green grid straight! The best I could do was align the red to the green and the blue to the green. The colors are not separated, however the top and bottom of the screen are warped. What would cause this, and how can I get it fixed?
  • 3 more comments
  • chelt Nov 13, 2007
    Where can I purchase IC's for my TV?
  • kukk Aug 09, 2008
    This has happened to our SONY projection 46" TV.
  • mikegorney Oct 16, 2008
    the same thing just happend to my phillips 60"
    the picture just warped in on the top and bottom
    were you able to fix this
  • snowryder2 Jan 03, 2009
    I have exactly the same problem.
  • Anonymous Apr 01, 2014
    I was watching TV this afternoon. Everything was fine. Turned off the TV and came back about 3-4 hours later and turned the TV on. Colors were way out of alignment...especially green. Tried to use Magic Focus and found that the green grid was warped. But the green grid isn't adjustable, only red and blue. So now what?
  • Philips Master
  • 3,459 Answers
You have a convergence problem.  Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors.  Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors,  etc. Everything you need to fix it yourself.
Posted on Nov 28, 2008
    Genius:
  • 1,694 Answers
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Posted on Oct 23, 2007
Okay, I replaced my convergence chips because I was getting the 3D effect. It seemed to clear some of the picture up, but I am still bowing at the top and bottom of the screen. As well as it looks like...
U still have a convergence problems,check all those resistors all around the 2 STK convergence ICS.All these resistors,must have the wright resistances and torance to have the tv to have picture convergence to function correctly.
Nov 03, 2010 | Philips 60P8341 60" Rear Projection...
My big screen tv shows only red green and blue. the colors are separated. what is wrong with it
the convergence circuit needs repair. You can get the convergence repair kit from www.tvrepairworld.com which contain the parts and the CD with instructions.
Sep 22, 2010 | Philips Magnavox 9P6034C 60" Rear...
Green lines up and down
Green slanted lines from left to right, especially visible on blank or dark picture is CRT bias circuits problem.
Apr 12, 2010 | Philips 60PP9352 60" Rear Projection...
Color is bad especially colors like orange and the white on peoples teeth is black most of the time andthe picture is not clear
HI, thank you for visit fixya.
Common problem on this set .
Picture tube liquid is dirty.
Mostly in crt green and crt blue.
Do you have electronics skills?. If so, open the TV ( back cover), you will see green,blue and red gun. After turn on your tv, select any channel or video signal, cover with piece a paper two guns at the top ( any), and see how look the picture in the front, try one at time, ( press menu on remote control and see leters-clear). I am sure the green and blue will be no clear. all the time red tube is fine.
REPLACE COOLANT LIQUID PROJECTION ( solution).
I will be here for any quetions.
Thank you
Dec 01, 2009 | Philips 60PP9352 60" Rear Projection...
Convergence problem...
even if you had the original remote you
could not adj the pic for the failing convergance
chips. have a shop swap the chips . its
takes me about an hour + .price should be
no more then 175.00 part/labor. ps you
will may need to order the original remote.
to set up the convergance , wait have the
shop do that for you.
Jun 29, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Philips model 60PP920217F
You need to replace both convergence ICs STK392-120 they are an easy repair you will also need (4) 6.8ohm Convergence resistors. You can get replacement ICs and the resistors at the following link and they will provide free installation instructions and free on line tech support so you will be able to do the repair yourself and save about 400.00 for a 45 minute repair. heres the link.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips hdtv color distortion
your tv has a prolem in the color circuit there is a ic that controls this circuit changing it will restore your tv to normal.since you are not a tech have a tech look at it for repairs.good luck.
Aug 03, 2007 | Samsung TXM3296HF 32" TV
My red and green colors separated
You have to go into your menu and into setup then look for convergence, don't know exactly where since the TV isn't in fornt of me. But once you get there, there should be a bund of "+" all the ones thare are in color you need to change to white. Depending on the TV you would use our left or right arrow keys, enter or ok. Hope this helps.
Feb 28, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
545 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
