Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Alot of red and double image
Double image
  • copsdonuts Dec 06, 2008
    Outer edge of picture is red or blue double image around border.
  • tflaman Dec 30, 2008
    It looks like I have the exact same problem.....
I have a panasonic cinema view 53' rear projection, turned it on today and have 2 green and red curved lines at the bottom of the screen any idea what this could be?
Thanks!
Posted on Dec 28, 2008
I had same problem. First went in tomenu and went to set up settings and went to convergence area. I then reset this back to default, which I later was told I should have not done so do not attempt this it will temporarily fix issue but problem will persisit.
I found a local tv repair man thru tvrepairguy.com or something like that as they are hard to find.
The issue turned out to be the convergence boards or circuits, He then went in to master control and rset the convergence settings for the main picture by lining up the red and blue lines on to a white cross on the screen until it is black and white with no red or blue protruding vertically or laterally. He then did this for 7 points around center picture moving the lines. He suggests you play with this for awhile in a position you would normally sit in and at proper eye level to give you the truest picture for alignment. The part cost 109 to replace with labor and service total was 331. The repairman was very nice and explained the issue should be fixed and we should get another 6 to 7 years out of television.
Hope this helps,
Posted on Dec 08, 2008
Hi. On my sony 57in. tv i am getting red arched lines over the entire screen, and double images. 5 years ago i had a similar ocurrence and the tech changed a module. What is the cause ? and why again so...
2 Things can cause this Red Tube needs to be adjust down on screen drive control or you need to replace Both of your STK ICS. Sony has alot of problems with Defective Tubes.Red and Blue Shorted out the most.
Mar 24, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Image double
convergence issues. i see this alot at the shop. i first suggest you read the article i wrote on the fl231 problem in my profile under tips and tricks. this might be a simple inexpensive repair. if this dont apply or help let me know and i see what i can do
Aug 16, 2008 | RCA R52WH73 Projection Television
Hitachi Projection TV sdx My picture has double images. The red and green seem to be separating out. Is it a serious problem or is repairing it worth it?
it will cost between 4 and 600 depending on where you get it repaired. If you post the model number to this same post I will list a link where you can get the parts and free instalation instructions where you can repair it yourself for alot less than a quarter of that price
Aug 15, 2008 | Televison & Video
Double image
yes you just need two ICs
Jul 12, 2008 | Akai PTH5498 54" Rear Projection...
Lot of red and double image
Hello ford2tough,
This sounds like a convergence problem. try to use the auto-adjust first but if that fails try checking the voltage on the convergence ICs and compare them to the values on the schematic diagram. What may have happened is a cold solder joint just broke or even an over heat stressed track on the board (uncommon, but has happend). If this is a cold solder joint the problem can be fixed by just re-heating the cold joint. If it is not a solder problem then the ICs have to be changed.
Sep 30, 2007 | JVC AV-48WP30 48" Rear Projection...
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
