Question about Frigidaire GLTF1240A Front Load Washer
Blinking lights and failure to start
The washer drain froze and the water flooded the floor. We thawed the frozen drain and let it all dry, then we tried to use the washer and the indicator lights are all on and the washer will not start even though the water lines are not frozen. We've tried to press the start and pause/cancel buttons down at the same time without success. We've unplugged the unit hoping to reset the control but no luck. We've pressed the option and pause/cancel button at the same time - no success. What can we do next to get the machine to restart?
  • RENe hogue Feb 07, 2007
    would appreciate any sugestions,thanks
    President:
  • 1,294 Answers
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Posted on Apr 16, 2007
The pipes froze and busted in my garage which cause water to burst in my Maytag Neptune front loader washer Now the water won't drain Please help
That machine has an electric water pump, The first thing I must ask is has it completely thawed out? There is a rubber hose that goes from the tub to the pump, if the water in the hose is still frozen in the hose or in the drain hose, it will not empty itself.Also the water water level switch is in the top of that hose. Another possibility, is the pump or the water level switch could be damaged. You can access the pump by taking the front panel off. That is not hard to do, requires removal of the door and a couple of other screws.
Mar 07, 2015 | Maytag Neptune MAH5500B Front Load Washer
Frozen winshield washer lines
Find a heated garage, you need to thaw out he lines, or use a hair dryer if you can follow the line path. When working, drain all the fluid by holding down the spray button on the car. Go and buy he heavy duty washer fluid with the lowest freezing point you can buy and refill your washer reservoir with it. Don't add any water Most likely you had water in the reservoir and it froze.
Jan 20, 2013 | 1998 Ford Taurus
My whirlpool Duet 9750 takes a long time to spin out and has a difficult time trying to balance
I owned a Whirlpool Duet and had spin/balance problems when I washed heavy and light items together. During a deep freeze my drain hose froze. Did everything I could think of until I ran hot water through washer. It took awhile to thaw. If your floor is weak, you will have a lot of vibration and walking. Hope this helps.
Dec 28, 2011 | Whirlpool LSW9750 Front Load Washer
We have a Bosch Washing Machine nexxt 100 series wfmc1001uc, the water lines froze without us realizing, we started to washer while lines were frozen... in the end, we had to replace the hot water inlet as...
Bosch Washing Machine nexxt 100 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 05, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
CSH22GR- water on floor, at left front of refrigerator (looking at it) approx. every other day. ? source ideas?
greetings,
The freezer floor may be frozen over with ice due to a clogged drain..the drain gets froze up and the water actually runs over the floor of freezer and goes out the door..if froze up..defrost and open drain..
Jan 24, 2011 | GE 21.9 Cu. Ft. Side-by-Side Refrigerator...
Used too much soap...miele flooded the floor....drain fault buzzer blinking what do I do?
by using too much detergent the float for water leaks inside the unit would have lifted and triggered the light to light. to clear the fault have some towels around the front of the unit on the floor and gently tip the unit forward and allow the water to escape. the float will drop down and you will be able to use the machine again.
any remaining water in the unit will just dry up. no damage would be done it happens all the time.
May 02, 2010 | Miele Touchtronic W1213 Front Load Washer
Frozen Valve Busted When Un Thawing and Water Ran through Washer
1st make sure inside is dry...Use a hair drier to make sure,could also be frozen pump outlet if it was that cold....
Feb 17, 2010 | Frigidaire ATF6000ES Front Load Washer
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Frigidaire GLTF1240A Front Load Washer Logo
233 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
