Question about Hotpoint Ultima WF860 Front Load Washer
Broken door handle Hotpoint WD860
Hi, Had a problem at weekend where the door would not open, found the solution on here :-)....now need to strip down the door to get access to the locking mechanism, I have undoone the screws on the back, but there seems to be quite a resistance to opening especially around the handle/locking area ??
Thanks Rob
  • rjtattersall Dec 04, 2008
    Its ok, worked it out, you have to slide off the outer half away from the handle slot.......now I just nned a new handle and rebuilt :-)
Managed to work it out, you have to slide the outer door case away from the handle locking mechanism, slide left and move away (after undoing the 6 screws on the inside) :-)
Posted on Dec 05, 2008
Hi, wondering if you could provide any information on how to remove the rhr door glass from a 2014 jeep Cherokee.I have the door completely stripped except for the door glass,can't seem to get it out
you will need to raise the glass , manually, until you can access the bottom of the glass where it connects to the opening mechanism and release (if not already at this stage) ,if you want the glass out of the door completely then you have to remove all the trims along the edge of door(weather strips) and around window/door frame , the seals ,the window will then be able to be lifted out , carefully !!
Oct 27, 2014 | Cars & Trucks
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
Main gear in door opener striped, model #41A30339.
With stripped gear, you definitely need to look at your garage door hardware! Openers are designed to 'guide' the door up and down, not push or pull. If you have a stripped gear, most likely the opener has been working overtime.
You can check the balance of your door, by disconnecting it from the opener and raising it manually up to about knee level. If it slides down on its own, your springs are fatigued and need to be replaced by a PROFESSIONAL (DO NOT WORK ON THE SPRINGS YOURSELF!)
You can view a how-to video at www.spokanegaragerepair.com/tips_tricks.htm
You can replace the gear and sprocket yourself if you have a few hours.. a professional will probably charge $150-$200 to replace, which- you can replace the whole opener for not too much more.
If the opener is more than 7 years old, I would recommend replacing the whole thing because all of the other parts will be worn as well, otherwise you can get away with just replacing the gear/sprocket.
Good Luck!
Mar 08, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
Hi, I have a Fisher Paykel DD603I (integrated) dishdrawer unit. The bottom drawer soap dispenser has water in it after it runs (and leftover soap), and there is a small amount of water sitting in the...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 16, 2011 | Fisher and Paykel Dishwashers
The soap dispenser on our BOSCH dishwasher, SHE4AM, won't open during washing cycles. Please help
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Dec 13, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Rear door glass fell down, will not wind back up.
do not force anything ,remove the door panel and have a look then post if you need more help ,but it sounds like the either the clamp or the support is loose or corroded away
May 30, 2010 | 2000 Jaguar S-Type
GE profile model GSD 4120y70BB the second soap dispensor does not open at the right time. When cycle is done and the door is opened the soap has just ran down. It is like it is opening to late.
Hi
Many dishwashers (but not all) use a BI-metal strip that heats up once power is applied to it. The BI-metal strip bends and allows the soap door spring to open up the dispenser. This bi-metal strip is not given full 120 volts power, the timer "shunts" the power through either the heating element ( most common ) or the motor and this gives the bi-metal strip lower than full power to work and open. Most often the bi-metal strip has lost its ability to bend properly and needs to be replaced. Older GE dishwashers used a mechanical arm driven by the timer to open the dispenser = no electrical bi-metals. Newer (plastic liner) Maytag dishwashers and many newer Whirlpool and Frigidaire dishwashers use a wax motor to open the soap dispenser; this wax motor does receive 120 volts to work. The plunger inside the wax motor slowly moves and pushes the plunger and door open. This is what a wax motor looks like.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 06, 2009 | GE Dishwashers
My printer always tells me paper jam
the issue can be found when the paper feed rolls in the printer or the internal encoder strip are dirty.
Please try the following:
- open the backdoor of the printer
- also open the front door
- unplug the power chord without shutting down the printer
- now clean the paper feed rolls inside the printer with a soft rubber
- turn the rolls some times (10 tries or so) from down to up
- close the backdoor
- move the cartridge cart some times from one side to the other
- now you see a transparent strip over the metal bar
- this strip you can clean with cleaning alcohol
(be carefully! don't loose the strip or take too much alcohol)
- now let the printer dry over night (let it be open)
- next morning, close the front door
- press # and 6 at the same time and hold them
- keep them pressed and plug in the power chord
- keep them pressed until you see "semi nvm reset"
done
Hope it helps,
Henning
Feb 04, 2009 | HP Officejet J5780 All-In-One InkJet...
2001 Nissan Quest - Broken Exterior Sliding Door Handle
you can do this. you have to remove inside trim panel for access. if you still need to do, I will send you repair steps. let me know
Oct 16, 2008 | 2001 Nissan Quest
When on/off button de-selected large flash from top of door. Main consumer unit tripped and fuse in plug found ruptured. Fuse replaced cb reset but dishwasher has no power. Fuse rechecked found to be...
Dishwasher stripped down and found MAIN WIRING HARNESS chaffed agains door during opening and closing. New loom in region of £100 so repared old loom.
Aug 08, 2008 | Dishwashers
Hotpoint Ultima WF860 Front Load Washer Logo
1,114 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
