Question about M-Audio Maudio USB Midisport 4x4 Multiplatform MIDI Interface - Sound Card
Midiman Midisport 4x4 USB freezes
Hi
I have purchased a Midiman Midisport 4x4, the blue and yellow one.
My system runs on a XP SP2 but I couldn't install the XP Sp2 drivers and went with the XP drivers. I have a m-audio 410 soundcard and the setup kept stopping because it stated "another m-audio device is connected" even after I disconnected and uninstalled it.
I have a USB midi keyboard and use Sonar 5. I routed the midi cable through the midiman to one of my hardware synths (Yamaha CSR6, Roland JV 1010, Virus...etc I ended up trying them all) Every time the midiman freezes after I play just a few notes. Playing the notes one by one seems to last longer but a chord or a signal from the sequencer freezes the midiman. It seems the data flow through the midiman might be the problem, although midi is old and slow. I have tried every thing I could think of: Installed the driver many times over. Tried the 2x2 driver. I have also switched the "allow windows to shut down usb device" in the USB root hub menu off. I have fiddled with the asio buffer settings, still no success.
My system is newly formated and everything runs perfect. There are also no resources problems as I don't use this computer for anything else and midi is such an old standard it works even on my zx spectrum.
Thank you very much for your time
Mihai
Well, all you need to, the midiman need chances you to chance it, try another one
Posted on Dec 04, 2008
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
Which USB card will work.
Almost ANY that list Windows XP on the side of the box.
Here is one for $9 that was rated 5/5 by 197 people. http://www.newegg.com/Product/Product.aspx?Item=N82E16815124008
Anyways, USB 2.0 has been out for many years, is a standard on all computers, and is 400x faster than USB 1.0.
Either way, I recommend you goto www.newegg.com, as all of their products, including their PCI USB expansion cards, have honest reviews from users that purchased them. I always read the reviews there before purchasing. And I would think 80% of the reviewers there even, have WinXP Pro SP2, however they will even state it alot of times, in addition to the Specifications page listing it.
Either way, very easy upgrade, have fun.
Sep 07, 2009 | HP Compaq ProLiant 1600 Server
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
System freeze
The issue was resolved by uninstalling SP3. I uninstalled SP3 and the USB PCI card and rebooted. When SP2 reinstalled the device it installed the corect driver (5.1.2600.2180) and everything is now functional. Have no idea why the correct driver was not in XP SP3.
Jan 24, 2009 | SYBA (SD-NECU2-3E1I) (SD-NECU2-3E1I) USB...
Midisport 4x4 delay problem
Hello Nelson,
What are the specifications of your mace and what is your studio set-up
Have you lookied at performance monitor to see what process is using up all the memory?
If sound like you may have to tweak your machine to suit your specific needs.
I too had similiar problems and tuned my machine to to work more effeciantly...
Feb 19, 2008 | M-Audio Maudio USB Midisport 4x4...
Iomega USB 2 Desktop Hard drive not recognised by xp sp2
did you set any jumppers to slave? Is it pluged in the right spot?
Nov 24, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Problems with reasons 4 in mac book to be recongnized
did you install the UB drivers? And which version of the drivers? Which os are you running?
keep me posted.
Nov 13, 2007 | M-Audio Maudio USB Midisport 4x4...
M-Audio Maudio USB Midisport 4x4 Multiplatform MIDI Interface - Sound Card Logo
409 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
