Question about Canon LV-5220 Multimedia Projector
No sinal Message
I have Canon LV-5220 projector, it was working ok before. But now when i connected to my Laptop /Desktop im gettin No Signal. I tried going back to Factory Default but im still getting the same message.Pse help
Http://www.sfsu.edu/~avitv/computerfaq.html
Try this link It worked for me JT
Posted on Jan 02, 2009
Canon lv-5220 multimedia projector flickering after start up
If it happens with no input hooked up then it could be the lamp. Or Worse.
Dec 05, 2012 | Canon LV-5220 Multimedia Projector
I have a problem with my Canon LV-7265 Projector. When I turn it on, a message appear "please clean the filter" with a blue windows! Please help me how to fix this problem. I try to clean 2...
You need to go into the settings menu and find the lamp reset and filter reset area, sometimes when you get to the reset part you hold down enter then an additional box may show reset/OK, select OK which should reset the filter hours. Most projectors have the filter reset but sometimes resetting can be difficult to work out. I had an old NEC where you had to hold down the on button of the remote for ten seconds to reset.
Hopefully this helps. There may be support from the manufacturers website plus downloadable user instructions.
Good luck
Aug 04, 2011 | Canon LV-7265 Projector
Our club owns a Canon LV-7240 which has worked OK. Last night we showed an NTSC DVD from Europe and no red showed. We could see what the colours ought to be on the laptop screen. On the big screen,...
Can't answer for the menu issues, but I can garuntee this is not a problem with brightness, contrast or sharpness, and very unlikely that you'll find a solution in the menu. What is likely is that the VGA wasn't plugged in properly initially. When the signal is going down the VGA it's broken up into 5 seperate signals, Red, Green, Blue and 2 sync signals. What is likely is that the green and blue pins havn't properly made contact either inside the projector or inside the laptop. This would also explain why it worked when you tried later because it made the connection properly. I would suggest trying again with the same laptop, if it does it again, try another PC without moving the projector or the VGA connector that's plugged into the projector. This will atleast narrow down your problem, but it doesn't sound like a problem with the projector to me. Also try plugging the laptop that wasn't working properly into a monitor (this will test the laptop)
Mar 25, 2011 | Canon LV-7240 Multimedia Projector
What is lifespan of a average bulb for LCD projector I have canon LV5220
am gong to say 3000-6000 hours at maximum but t depends also because your device has a Max. Resolution of 800 x 600.and that s essential for bulb lifespan..so m sticking with 6000hours
Nov 16, 2010 | Canon LV-5220 Multimedia Projector
Canon LV-S2 projector not work with component signal input
Try unplugging the projector. This seemingly works but I can't figure out WHY....
Mar 18, 2009 | Canon LV-S2 Multimedia Projector
Big Green Bar
Hi Tom017
Does this green bar show even when there is no signal inserted into the Projector ?
If it doesn't then you can try using a different cable - that should solve this for you.
If it doesn't then you might be in for a quite expensive Mainbaord repair or replacement.
Good luck and thanks for using Fixya !
May 06, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
SOURCE PROBLEM
Hi John
Is your Projector's source scan swithed on ?
Does it pick up a signal when you press the source button ?
Apr 20, 2008 | Canon LV-7230 Multimedia Projector
Display
Hi, Yes it is possible but.... Your laptop version may either be using an NVidia or an ATI. If an NVidia, right click on any clear area of your desktop, click on Properties, (in Display Properties) Settings, Advanced, TwinView tab, Clone, Apply, OK, Yes (if you want to keep this setting), OK. Am not sure if it will work with the ATI version, right click on any clear area of your desktop, click on Properties, (in Display Properties) Settings, Advanced, Display, TV button, Primary (display only on projector) hope you have other setting like LCD + TV (display on both), Apply, Yes (if you want to keep this setting), OK. Your Canon LV-S3 Multimedia Projector's Native resolution is 800x600 max @ 1280x1024 Pixels. You may need to set your laptop to the lowest first and gradually work it up till the projector no longer can display, then back down one notch. You may also need to press on Fn + F8 a few times to check if you can switch displays: LCD, TV/projector, LCD + TYV/Projector. You can try either the S-video TV-out connector or the video connector (both at the back). Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 16, 2007 | Canon LV-S3 Multimedia Projector
Canon LV-5220 Multimedia Projector Logo
203 people viewed this question
old marine
old marine
