Question about Canon NP 6050 Copier
ONE HALF BLACK PAGES WITH SHARP SF-2414
ON THE LEFT HALF OF THE PAGE, I GET NOTHING BUT BLACK. THE BLACK BORDER RUNS DIAGONALLY FROM RIGHT TO LEFT DOWN THE PAGE.
I HAVE ALREADY CHANGED THE DRUM AND THE DEVELOPER LIGHT DOES NOT INDICATE A NEED FOR A CHANGE.
ON THE RIGHT SIDE OF THE PAGE, I GET THE COPIED IMAGE.
    Genius:
  • 1,239 Answers
Hi You clean Heat roller, Thermostate or thermostator
if you does not solve you can clean your machines laser unit
Posted on Dec 04, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 04, 2008
    chek the copier lamp(upper lamp ) if its working during copy other ways u have to take up the lamp and check it by oem meter , u have to check also the thermal fuse for that lamp on the same unit. I hope that will solve ur problem ,if not high voltage unit above the drume is damaged
  • ABHISHEK.C
    is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
  • Canon Master
  • 19,396 Answers
Did you clean the inside of the copier from toner and dirt?
  • Ginko
    Ginko Dec 04, 2008
    If you already replaced drum, lets exclude a drum problem, even if the drum should be checked. Just remove the drum and put it back inside. On some model, the drum , the toner , and the film unit are separate, check also the remaining parts.
    I would exclude problem with fuser lamp, as this cause generally a white portion of the print , and not a black area.
    If you havent tried a replacement toner yet, replace the toner, clean the machine, and print some copies.
    If the drum is OK, and toner is fine and machine cleans, then this is usually a defect that concerns the laser gun good working, or a scanner problem.
    Check that te scanner area is not dirty, that mirror and light are fine, this can be easily a bad scanner sensor.
    Check that the inside of the copier does not have dirty areas inside, if you know how to clean safely a copy machine, you can clean the inside of the machine from residual toner.
    Often this is also a DC controller PCA fault.
    If DC Controller is defective, it will
    turn on the laser beam continuously, or erratically, causing an entire portion of the Photosensitive
    drum to be neutralized, and printing a completely black area.
    You can also get this when the high voltage power supply circuit is defective, and it is not supplying the correct negative voltage, in this case part of the page may be black.
    Finally, when the Laser or Scanner Assembly itself is faulty it will turn on laser
    on continuously, and can print a dark area on part of the page.
Are there cleaning sheets for Sharp SF2414 duplicators?
Hello Paul,
There are no "cleaning sheets" for this unit. Typically when this unit starts leaving marks on printed copies then it is time to do some maintenance on it. By maintenance I mean replacing the imaging drum, the toner and or the developer, all of which can be ordered from this link; Sharp Monochrome Copier Copier Duplicator FREE delivery If you don't feel comfortable then you need to call service!
Mar 04, 2015 | Sharp Office Equipment & Supplies
I have a sharp sf2116 copier. when copying i am getting half of the page printed properly but the other half is feint. i have renewed the toner.
problem is not the toner , could be the developer unit stopping at that point when it becomes feint and then no new toner gets to the drum,
OR
it could be the transfer section
Aug 06, 2013 | Sharp SF 2020 Copier
What are the parts of microsoft word?
Microsoft word is a program, there are no physical "parts" to it. If you mean Microsoft Office, there is:
Word Excel Powerpoint Entourage/Outlook OneNote (Schooling version on tablets)
Jul 06, 2011 | Computers & Internet
Website is right screen centered for one given website. want to display it at center screen
The following is an illustration of an entire body element (with a black border for clarification purposes) centered on a page. A width must be set for the element, then the left and right margins are set to auto. Here's how:
body {
width: 80%;
margin-right: auto;
margin-left: auto;
border: 1px solid black;
Try this
Aug 08, 2009 | Computers & Internet
I own a sharp SF-7900. My pages are coming out black
I'm sure you may find a manual, but your copier is rather old.... When you make a copy do you get a error code? How about when you make a copy, do you see the scanning lamp turn ON? Here is you thing you can try, make sure the Primary Corona unit is pushed in all the way in. It has a grey handel on it and it should be found right above the Drum... Good Luck
Apr 19, 2009 | Sharp Office Equipment & Supplies
Black border down the right side of the page, which blocks info
either you neede a new drum or this is problem in the fuser section. may be baf heater roller. try cleaning the grid on the drum cartridge with a soft bristel pauint brush good luck brother sr tech
Jan 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Cannot minimise yahoo messenre window
Click middle icon in top right corner until only 1 rectangle shows
Drag the whole page to the left by grabbing the top border and dragging and dropping the page until you can access the right hand border
Drag and drop the right hand border to the position you want.
Do the same with left hand border
Check default by maximiize & restore down
To increase page size Crtl & + ( in stages )
To decrease page size Ctrl & - ( in stages )
To restore default Ctrl & 0 ( zero )
Dec 05, 2008 | Yahoo Messenger
AL-1631 Copier puts a black line on each page
does the line go across the page & move ? then your drum needs to be replaced.
Dec 01, 2008 | Sharp AL 1631 Copier
I have a 1 inch on the left and right side how do I get full scre
if you hav a monitor separate from your computer(not a laptop)then just use your settings on the monitor untill it works again the way you like it..
or for laptops and monitors with no controls on them go 2 control panel>>>>appearance and themes>>>>display. then click on the tab that says settings. go 2 advanced and the dpi setting should be set at 96....and if nothing changes go 2 the appearance tab then 2 advanced. and at the bottom for the item look for active window border and the size should say 1. if it does then keepo trying to make the number bigger so your page doesnt have a black border
Nov 30, 2008 | Gateway Computers & Internet
Canon NP 6050 Copier Logo
266 people viewed this question
old marine
old marine
