Question about StarTech.com StarView SV211K 2-port KVM Switch
No signal My box just says no signal, any one know what to do
  • david gill Dec 04, 2008
    new codes for starviewbox. old codes F0 83 35 E5 28 40 49 B2 .NEW CODES FOR PLEASE
    Problem Solver:
  • 12 Answers
Go to this website and download the fix there all there http://www.bigmaq.co.uk/
Posted on Dec 04, 2008
You gave too technical an answer . I'm 80 years old & don't know what you are talking about.
Assuming you have a TV hooked up to some kind of cable box, I would venture to say the TV is telling you it is not receiving a signal from the cable box.
Two things could be the problem;
1 You are on the wrong channel to receive a signal - some boxes send the signal to you on channel 3 - if your TV somehow got changed to channel 4, for example, it would not recognize the signal from the box. Make sure you are on the correct channel setting.
2. The cable box may not be turned on or formated properly. Turn the box off and then back on after a few minutes. Follow any messages on the screen on the box for a proper start-up.
If nothing helps, call your cable company for assistance..
Feb 23, 2015 | Televison & Video
Had a lightning issue the other night and now my Vizio tv will is not able to find satellite signal. Netflix works and can pick up Wi-Fi signal .....there is a good picture but it says searching for...
If it says "searching for satellite" the problem is in your satellite receiver, not the TV. The TV is working. Its showing you the signal coming from the sat box. The sat box is the tuner and is responsible for the sat signal. The "searching for satellite" is a common problem after lightening issues. If you have multiple sat boxes, then swap this one with another that you know works. If this is your only box, call your provider as it means the dish LNB or the sat box was damaged by the lightening. Also have the wiring checked for bad grounds due to an improper install.
Dec 21, 2017 | Vizio VO420E 42 in. LCD TV
Ok i don't know about much about cars but i know
sounds like the signal switch relay fuse. turn your signal on and check your fuse boxes... inside the car and under the hood. it will look like a little square box inside your fuse box next to your other fuses. with your signal on, you should be able to locate the relay because it will be making a clicking noise. pull it straight out and go get another one. hope this helps.
Nov 03, 2012 | Cars & Trucks
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
My 1993 crown victoria's signals are not working, my headlights and taillights all work. what is wrong and how do i fix it? i dont have alot of money and need to know how to fix this on my own.
CHECK TURN SIGNAL FUSE IN THE FUSE BOX LOWER LEFT SIDE OF THE INSTRUMENT PANEL.IF FUSE OKAY PROBLEM COULD BE THE FLASHER IN THE FUSE BOX ITS A LARGE ROUND METAL TIN LOOKING FUSE.YOU SEE IT IN THE INTERIOR FUSE BOX.IF FLASHER GOOD.TURN SIGNAL SWITCH COULD BE FAULTY.SHAKE TURN SIGNAL SWITCH WIRES CHECK FOR SHORTS.
Nov 21, 2010 | 1993 Ford Crown Victoria
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
Not picking up Digital signal from box but can receive it analog
So many factors could be affecting your reception. Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital. Your converter box when turned on will probably not pick up the standard signal. The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get. Let me know and I can help further.
lone99star
Jan 09, 2009 | Emerson EWL20D6 Television
1993 ford ranger supercab
the fuse box is inside the pickup under the drivers side dash, there is a flasher which is the round one in the fuse box, it controls turn signals and emergency flashers also in the same fuse box, there is a 15 amp fuse which controls just the turn signals it sits vertical instead of horizontal.
Jun 10, 2008 | 1993 Ford Ranger SuperCab
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
StarTech.com StarView SV211K 2-port KVM Switch Logo
35 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
