Question about Toshiba TP50H50 50" Rear Projection Television
TP50H50 Black Box on screen
TV appears to be in permanent DEMO mode but it's not showing any of the DEMO. If I press the DEMO button it's starts, but when I exit the black box still stays on the screen. I got into the service mode and the picture clears, except the little "S" that's on the screen. Any ideas as to how to clear this up?
You may have the set in text mode (part of the closed caption menu)
Posted on Apr 19, 2007
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 03, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Tv has black square in right bottom of screen
Hit the set up button on the TV.
You'll see options to change the language. The last option is to put the TV in "Demo Mode."
Put the TV in Demo mode, when the first screen appears, "Welcome to...." the PIP will disappear.
Hit exit before the screen moves to the "Menu." If you miss it, watch the demo once--it will restart--and hit the exit button the next time you see the "Welcome to" message.
I just did this and it worked for me - i hope it works for you
Dec 29, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Store Mode is ON.
for Bravia's.. To turn off the demo mode, press and hold the MENU button on the TV for more than 10 seconds. The message Demo mode: Off will appear on the screen.
Let me know if this helps.
Feb 21, 2018 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Black Box on the screen
It sounds like a text box that isn't receiving any text. If it covers almost the entire screen, then you might have accidentally got the settings into DEMO mode. It could also be a box for closed captioning, but that usually covers just the lower part of the screen. Either way, the solution is to go into the setup menu and restore facotry presets.
Nov 27, 2008 | Toshiba 27A33 27" TV
JVC AV-27430 27"
Go into your settings of the TV menu or there will be a single button on the JVC remote marked "CC" for closed caption. Press it or in the menu turn off the "TEXT" mode. With the text mode on you are allowing the TV to display text information wich means usually a black rectangular box that appears on the screen with no text in it. Usually on the cc button just press it until it scrolls through turning off the CC or text modes.
May 24, 2008 | JVC AV-27430 27" TV
Our TV reset itsself to sales pitch
1) Demo mode clears by holding vol up & chan up at the same time at the set front buttons. Or try menu & power.......
2) Black box is called a text box = part of closed-caption option.
Select CC to turn text box off.........
Note:Always provide Model # , Chassis # and age......
serial # not needed / helpful..........T.
Nov 05, 2007 | Televison & Video
Toshiba TP50H50 50" Rear Projection Television Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
