Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
Gas not getting to 2 ovens
All burners & grill working, but gas doesnt appear to be getting to ovens
  • 294 Answers
Please do look for the solution.. in the folling link.....www.hometips.com/repair-fix/range-gas-burners.html
Posted on Aug 02, 2009
Oven takes too long to start or not at all
is this electric or gas? if it is gas and a newer model it has an ignitor that heats up that will then ignite the gas burner, the ignitor is bad or you may need to inspect and clean the gas ports on the burner as they can get cloged up over time, try the inspection and cleaning first. If it doesnt appear to be cloged then turn on the oven and watch the ignitor, if it doesnt heat up to be white hot then it is bad or going bad and should be replaced. if it is electric check to see if the heating element is working by turning the oven on and watch for it to glow red hot, if it doesnt then it will need to be replaced.
Sep 08, 2014 | Ovens
I just replaced and old worn out built in Turbo with a new model. Both are propane versions. After installing the new model works fine but does not generate enough heat. With all four burners on high...
If you are using a 20Lb LP Gas Tank, rather than hard piped to the grill or you're using Natural Ga, here in may lie the problem. If it is Natural Gas, was the grill converted or ordered for Natural Gas? If not, that's why it' not heating well.
If you're using a 20Lb grill tank, do the following:
1. Turn the Propane Tank Valve OFF and disconnect the hose from the tank.
2.Wait 5 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
3. Once the valve is fully open, light the burner farthest from the tank first and turn the control knob to HIGH. Does the flame height look correct for being on HIGH? If so, light the remaining burners the same way, Do all the flame hieghts look correct? If co, close the lid and allow the grill to preheat for at least 20 minutes. Did the grill thermometer go higher that 200 degrees F. If so, you solved the problem. Always remember to turn the tank valve ON very, very slowly.
If that did not solve the problem, the thermometer may be incorrect/faulty. I had this happen myself, with a new grill. To test it, invest $5.00 in an Oven Thermometer, like you use in a regular oven, It sits on the oven shelf. But, in this case it will sit on the center of the grill's cooking grates.
Light the grill and preheat it for 20 minutes. Loo k at the grill thermometer and then lift the hood and look at the oven thermometer. The oven thermometer may be as much as 200 degrees higher. That's because it's actually reading the temperature at cooking level, not up in the air, where the grill thermometer is.
I never replaced my grill thermometer. I continue to use the inexpensive oven thermometer, because it's giving me the actual temperature, at the level I'm grilling at. And I, do a lot of grilling.
Hope this helped you troubleshoot and solve the problem. Pleas let me know and Happy Grilling.
Jun 24, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
My main ignitor works and the side burner ignitor doesnt...it not 1 year old yet
Check the ignitor wiring going to the side burner to make sure that both leads are stil connected (ie making contact). If it appears that they are, remove the end of the wire on the side burner igniter and push it back on again. It may have just lost the ground to it.
Jan 30, 2011 | Fiesta Blue Ember Gas Grill
The grill will not light
It may be the regulator replace that and you should be ready to go!
Jul 06, 2010 | Weber 2780001 Summit S-470 Gas Grill
Our grill doesnt seem to be getting enough gas to stay lit. when you turn the burners on your hear the gas coming through for 2 seconds..then nothing, and it wont stay lit
How are you turning the grill on and off? It sounds like a vapor-lock. Try this: first unhook the regulator and crack the valve on the tank open...if you hear and smell gas coming out, good, close the valve and re-connect the regulator then open the gas valve then turn the burner on and light it...then shut it off by closing the tank valve first and let the burners go out then turn off your burner valves...try that and let me know what happens.
Sep 06, 2009 | Grilling
Problem with gas getting to the front burner
Follow manufacturer's recommendation in resetting the excess flow safety device....(Turn burners and LP cylinder off...Disconnect regulator on cylinder. Turn both knobs to high for at least one minute...Then turn them to off...reconnect the regulator to the LP tank...Turn LP valve VERY slowly (30 seconds) until fully opened..then start the grill in the usual manner. ALWAYS TURN THE LP TANK OFF WHEN DONE USING THE GRILL....
Jul 04, 2009 | Weber Genesis Silver B Grill
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
Ignitor problem?
if you remove the 2 screws on the right and left bottom plate and open the door and youll see 2 screws that panel will come off turn the oven on and you should see 2 burners on both sides and they should ignite.if they do and go right out you could have 2 problems.when the burners light they hit a probe called a flame sense.this probe plugs into a heat board and if the board doesnt sense the flame you will get a red no ignition light.clean the probes that sit right on the burners with sandpaper and see what happens,if that doesnt work if the unit has pilots clean the pilot orfice and if that doesnt work the heat board may be bad.how old is the unit?
Feb 25, 2007 | Vulcan VC44GD Gas Double Oven
Checking my furnace's ignition
Gas burners serve as the primary source of heat in a variety of home appliances: water heaters, gas dryers, and gas cooktops and ovens, and-of course-- furnaces and boilers. When the burner fails, most gas appliances are designed to stop working altogether to prevent a gas leak. As a rule, it's best to have gas burner problems fixed by your gas utility service person or a qualified heating technician, but there are a few steps you can take to avoid paying for a service call.
Jan 18, 2006 | Coleman 2 Burner Compact Gas 425F499G...
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
138 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
