What signal is sent over the center pin of the power adapter?
As i found out on the internet my Dell x300 latitude cannot charge the battery because i use another ''Dell'' adapter with the same ratings though. The cause is the signal sent over the third pin by the original adapter and tells the laptop to be able to charge the battery.
My question: is there anyone with the original adapter who can view this signal on an oscilloscope? Maybe it is just a steady voltage that is needed, maybe a complex digital code, maybe a simple one that can be imitated by a simple circuit.
Anyone have any ideas about this?
  • Joe May 11, 2010
    What is the adapter PA Family? ie PA-6,PA-9 etc.
  • 81 Answers
The problem isn't in the psu - it's in the laptop. The centre pin supplies a trigger voltage with a simple carrier which tell s the BIOS about the power characteristics of the unit. Missing that signal, the BIOS assumes that even though there may be enough power to run the laptop, there may not be enough to charge the battery - a situation that, on lower power PSUs, can lead to damage to PSU and/or laptop. That's a safety feature that it doesn't attempt to trigger the charging circuit. The most likely reason for that trigger being missing is the (very poorly-designed) PSU interface having become disconnected from the rail. The socket needs replacing.
Posted on Jul 21, 2009
I have a Dell E6400. I know, ancient! Is it normal that it gets slower when charging? Like when it's using battery power, it's noticeably faster, but when I plug the charger in it just gets slower..
1.Install the system again. If it works, over!
2.remove the battery, and turn on your notebook with charger. If it works, there may be
something wrong with your battery. You can change a new battery.
3.Install the battery,and plug the charger, power your notebook. Open the Power
management, change the Power plan to High performance.
4400mAh 6 cells Dell Latitude E6400 XFR Battery Replacement Notebook... 90W Dell Latitude E6400 Charger Power Cord Replacement AC Adapter Latitude...
Jan 12, 2017 | Dell Computers & Internet
What are the Schamatics to a Dell ac/dc adapter MODEL: DA90PS1-00
Specification of DA90PS1-00 AC Adapter:
Output: DC19.5V 4.62A
Power: 90W MaxOutlet: 3-Prong
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin
Sep 18, 2011 | Dell Laptop DC Power Jack (DELLDL271600)...
My Dell Latitude x300 monitor is dark (black) while the computer is running. I plugged it into a stand alone monitor and it was also black. how do it fix it.
Your graphics card adapter is damaged!
buy a new card to your dell laptop
and let someone with experiense change it.
This is your solution! Please vote!!!
Feb 28, 2010 | Dell Latitude X300 Notebook
Universal power supply targus tip for Dell Latitude D620, won't charge battery, pop up says slow and no (charge), use only Dell. Is there a Targus tip that will go on Model APA10 Targus Universal power...
the problem is the BIOS of the Dell system is looking for an ID signal from the AC adapter so it knows what adapter is connected. If the BIOS cannot ID the power supply, then battery charger is disabled.
You will need to get a Dell AC adapter.
http://www.discountelectronics.com/index.php?l=product_detail&p=1459
Feb 15, 2010 | Dell Latitude D620 Notebook
My Dell D 600 will not charge the battery and a message appears at start up that says Ac adapter not recognized What do I need to do to get my computer to charge the battery
If the AC adapter is not recognized by the system, the battery charger circuit is disabled. Things you can check:
  1. In the barrel of the connection to the computer, the small wire in the center is the sensing wire. If bent or broken, then the adapter will need to be replaced.
  2. If the pin is not bent or broken, try a different AC adapter (Any D-Series Dell adapter will work) IF that adapter works, replace the AC adapter.
  3. If a known good/new adapter doesn't resolve, then a motherboard needs replacement.
Jan 10, 2010 | Dell Latitude D600 Notebook
Bought a x300 latitude dell laptop. Powers on with ac power adapter, but batteries will not charge even when left plugged in for 6 hours or more. Could it be a bad motherboard??
It could be a faulty battery or a faulty charging circuit.
Rechargeable batteries have a finite number of charge and recharge cycles. There capacity reduces with age until they reach a stage where they won't charge at all.
Oct 24, 2009 | Office Equipment & Supplies
What signal is sent over the center pin of the adapte pug?
my best bet to say for to go to an electronics store and mach up a new one, because to try and test the one you have now would be more costly than to replace it. biigg53566
Dec 04, 2008 | Dell Latitude X300 Notebook
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
