Question about GE Wireless Optical Mouse
GE Wireless Optical mouse 97990 Rev. 4
I cant get to get this thing to work... it was working fine for a little bit... for a week or so (I didnt pay attention because it was working fine :D ) so id you have any suggestions please help, i know im not the only one out there thats having htos problem :( plz help so i can stop using my stuped touch pad lol The Jman, The.Jman@mail.com
  • leel99 Nov 08, 2007
    just got the Wireless optical mouse HO97990 and it does not work
    Sergeant:
  • 310 Answers
You need to plug in the USB reciever load windows till desktop appears, hold down the reciever button until it flashs then quickly turn over mouse and press connect button in. and you should see the reciever flicker, and it should start working. if it dont try swapping the batterys as they dont last long...and repeating the same process Hope this helps John
Posted on Mar 01, 2007
  • good1 Sep 07, 2010
    I read other solutions that said the same thing but this one was in detail. I didn't know the usb receiver would flash. I held it down for a few seconds and seen the flash, then hit the connect button under the mouse and it worked. Thanks.
Plug in receiver. then turn on mouse with switch on bottom. next press the link button on the receiver, then quickly press the link button on the mouse. they will then sync together and start working.
Posted on Apr 28, 2010
  • theabrams Mar 09, 2011
    Worked for me!! I had this mouse for almost two years and never used it! Thanks!!!
Awesome, I was having the same problem and this fixed it! thanks so much!
Posted on May 29, 2010
Throw this mouse against a brick wall. It's a piece of junk. It's not even worth 2 dollars, I cannot believe I spent 15 dollars on it. Now take the other piece, and go around wacking people in the head with it.
Posted on Jul 24, 2008
SOURCE:
Install ge wireless optical mouse 97990 rev 4
You need to install the radio receiver to the computer via usb. then sync the devices. Usually a button on the receiver or mouse should do it.
Nov 17, 2011 | GE Computers & Internet
I have #97990. The batteries are done within a half of a day, even when I switch it off
Replace the rechargeable batteries. Even rechargeable batteries only can be recharged so many times and then they will not hold a good charge.
Oct 29, 2010 | GE Wireless Optical Mouse
GE Wireless "Malfunction" "Unknown Device"
Does the mouse and/or keyboard have a "connect" button on the bottom of either? Try restarting your PC, then, if you have installed new batteries, and the mouse/keyboard is still not connected, try the "Connect" button if any.
Jan 01, 2010 | GE Wireless Optical Mouse
Wireless optical mouse #97990 Rev 5 does not work
Remove the batteries. Remove the receiver from the PC. Reinsert and try to link them again.
Aug 31, 2009 | GE Wireless Optical Mouse
Is ther a trick to make it start working again?
Did you press the little connect button on the bottom of the mouse??
Jun 01, 2009 | GE Wireless Optical Mouse
97990 Rev. 4
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 30, 2009 | GE Wireless Optical Mouse
Mouse thinks its alive (GE wireless optical 97990 rev.4)
Could be signal interference or overloaded usb port. Move receiver around to get a more direct signal, and notice any other devices in use like phones. Use alone without other usb devices plugged in and/or buy usb hub with power adapter. DO NOT buy passive usb hub with no additional power.
Nov 18, 2008 | GE Wireless Optical Mouse
Wheel won't scroll
Hello, Please do service of your mouse, may be due to some dust over the scroll thanks
Sep 08, 2008 | GE Wireless Optical Mouse
New mouse, still has problems
Some mice eat batteries like they are nothing. I myself have a logitec wireless mouse and i must replace the batteries every two weeks. I would suggest getting another mouse.
May 24, 2007 | GE Wireless Optical Mouse
GE Wireless mouse 97990 Rev 4 stopped working
From the Jasco website, some other options to try: Batteries: Tracking can be affected by low or dead batteries. Try replacing the batteries with a fresh set and test the tracking. Although you can use rechargeable batteries, alkaline batteries have been found to have the longest battery life. Interference with other electrical products: Other electrical devices may interfere with the radio signal that the mouse uses to communicate with the receiver. Try placing the receiver in a different location, away from the monitor, zip drives, and other electrical devices. Also, try rotating the receiver so it is on its side (or back). Range of the receiver: GE cordless pointing devices can transmit a signal up to 2 meters (appr 6 ft). Make sure the receiver and mouse are within the 2 meters of each other.
Dec 20, 2006 | GE Wireless Optical Mouse
GE Wireless Optical Mouse Logo
1,804 people viewed this question
Top GE Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
