Question about Dayton (3E379) Heater
We have a CD masher w dayton motor 5k934d need wiring diagram
Call me @ 916 342-4313
Posted on Dec 11, 2008
  • kotermack Dec 11, 2008
    call @ 916 342-4313
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Wiring diagram for dayton 5k652a motor
Hi. I think these website may be able to show or provide that diagram you need: industrialscientifictool. Com. Or. freeproductmanual.com. I hope this helps
Mar 22, 2015 | Dayton Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
May 21, 2013 | Pool & Spa
Wiring for a Dayton motor 6k857L
Wiring diagram appears on side of motor.
This motor is rated 115Volt.
Hot and Neutral wires connect to main terminals.
Connect other wires as shown on label.
For example there can be yellow, black, blue and white wires.
Dayton manufacturing is owned by WW Grainger.
Contact Grainger.
http://www.grainger.com/Grainger/static/help_contactus.html
Oct 12, 2012 | Dryers
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
I have a dayton 3/4 hp fan motor. I need to change voltage from 230 to 115. Where can I get a wiring diagram showing the wire changes that I need to make. I have done this before but forgot which wires...
There are many different types of motors. you should have a diagram on the inside of the wiring compartment cover. This is a dayton diagram, but I can't be sure it is the same as the motor you have.Notice line terminals remain the same, but that the internal wires change terminals.
Aug 05, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I need a wiring diagram for a farm duty 6k714k
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
Jun 05, 2010 | Dayton Audio Dayton 6K138 CapacitorStart
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Dayton (3E379) Heater Logo
211 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
