I uninstalled roxio using smart uninstaller and now i cannot re install roxio it keeps freezing on installation
  • 2,110 Answers
here u can find process to completely remove roxio....
Posted on Dec 04, 2008
I have installed, uninstalled, and reinstalled Roxio Easy VHS to DVD several times. I keep getting a " certificate is missing or corrupted please reinstall" message. I am thinking about...
When you use the Add/Remove Program tool to uninstall an application, Windows reads the installation log that was created when you first installed the program and relies on the information
contained in the log for direction. Problem is, this usually results in changes made to your Registry
being left behind.
Reinstalling the same application after a less than thorough uninstall procedure can sometimes
result in registry corruption and other nusances caused by file clutter left behind.
It's always good practice to create a system restore point before installing any new application,
which gives you the option of simply "rolling back" the system to its pre-install state. Absent that,
I recommend you not rely on Windows' Add/Remove Program tool to handle your uninstalling.
Instead, use a third-party utility that does a better clean-up job.
I've had good results with Revo Uninstaller. Revo offers a freeware version in addition to a 30-day
trial of it's Pro version.
Good luck, and I hope this helps :)
Jan 04, 2011 | Roxio Easy VHS to DVD for PC
Microsoft Visual C++ Runtime Library error when starting Roxio creator
I have had several questions from users getting Microsoft Visual C++ Runtime Library errors when starting Roxio Creator 2010 and previous versions.
After the error prompt, the software will close down.
The problem is caused by a system error , and this sometimes is causedby Microsoft self installing update, that confuse settings of installedsoftware.
Microsoft Visual C++ Runtime Libraries are part of the operativesystem, and this kind of Run time errors are commonly caused whenapplications try to access resources that are allocated for otherprocesses.
A new Roxio installation did not fix the problem, because the newinstallation will still keep the registry settings from oldinstallation.
If the problem started recently you can try the following:
Uninstall Roxio.
Do a System Restore to a date before the problem started.
Reinstall Roxio.
See: How to install System restore.
If that does not fix the problem you can also try the following;
Uninstall Roxio
Create a new user with administrator privileges
Log in using the New User account
Install Roxio again.
If the problem was bound to local user settings, this will fix the problem.
If the problem is still there, then the most efficient way to proceedis by doing a new Windows installation, using a Windows setup disk or arecovery disk for your computer.
Do a full backup of your data before reinstalling Windows.
See:Install, reinstall, or uninstall Windows
The solution does not apply only to Roxio, but can fix the same problem on different software.
on Feb 26, 2010 | Computers & Internet
My roxio media creator 7 program that came with my burner was having trouble.It said to re-install it.I put the disk in and it says im missing a certificate and it wont install.It wont let me uninstall it...
OK - if you installed IE7 or WMP11 remove them before starting. Uninstall EMC from add/remove programs. Download and run the MS Cleanup utility and remove all traces of Roxio
After you install it go to the program folder and click on msicuu.exe. If some files in roxio are still left download, install and run;
Click on the Registry icon and scan for issues.
Godd luck!
Apr 28, 2010 | Computers & Internet
How to uninstall deep freeze version ? i can't find the uninstaller for this program anywhere in my pc. thanks in advance.
Smart Software for Deep Freeze v.6 to disable or uninstall this software in this time there is no. But with little tricks, Deep Freeze 6.0 can be disable or unintal not requiring password. following way to disable or unintal Deep Freeze ver 6 :
  1. Booting Computer From CD use Windows XP Installer
  2. After coming up with part to Enter Setup, Press Enter then F8 and await some moment
  3. then selected R to repair Windows ( Repair Setup)
  4. Hereinafter continue Install windows untill finish.
  5. Now prepare the Deepfreeze v.6 of and double click
  6. will appear “Uninstall Deepfreeze” windows and process uninstall till finish.
  7. Done……
Apr 21, 2010 | Computers & Internet
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
Roxio's Easy Media Creator 9 Windows XP locking up
uninstall it or if you cant start your computer reload windows from disc. media creator may be too "big" for your system. pentium 4 min.required,i should think no easy way out if its crashing your computer
Apr 21, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
Roxio Cine Player Decoder Pack instalation package
Remove any older versions of Roxio or Sonic from the computer and do a clean install (uninstall then reinstall).
Mar 30, 2009 | Roxio Easy VHS to DVD for PC
Removing Roxio media manager
You can try to download revouninstaller or ccleaner, to uninstall the programs.
Oct 15, 2008 | Dell Inspiron 1300 Notebook
the bus settings may be the settings that have been changed by roxio, if you havent uninstalled the previous burning programme. Try uninstalling any burning programme you have, restart the pc and install the programme you require. If it continues you may need to uninstall the drive, by way of :- my computer>properties>hardware tab>device manager and look down list to dvd/cdrom drives and click '+' sign to your dvd line and right click and uninstall. Restart pc and it will automaticaly install again, ready for use.
May 11, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Computers & Internet Logo
David Payne
David Payne
