Question about Vizio P50HDTV10A 50 in. Plasma HDTV
TV works, but DVD play gets no response
My 50 inch Vizio seems to be out of whack. We've had it for a year used the DVD player, Wii and VHS player without incident. I swear I didn't change a thing and one day none of the extra components will function. Checked out all the connections and nothing seems to be wrong there. I am assuming the problem is with the TV since I can see the players running, but no picture or audio appears on the screen. However, I am a total tech idiot so any advice will be appreciated.
  • mrt43 Dec 04, 2008
    Thank you! Unplugging the TV worked.
I had the same problem, I turned off the power for 5 mins, let hdtv reset, i rlugged in dvd player, into either inputs and they all work.
Bravo!
Posted on Mar 02, 2009
    President:
  • 2,992 Answers
Since all the source switching is under control of the computer in the set, if none of the external sources comes on it's got to be the TV's fault. First try unplugging the set and giving it 5 or 10 minutes and plug it back in to allow the processor to reset. If the external stuff still doesn't show up, check all the menu options to see if anything allows you to disable them (parental lock, for example). If nothing else works, the set may need a service call.
(I'm not too familiar with this brand and don't have service information. But I have seen other brands behave this way when something messes up the control system and the computer inside doesn't know what features it has anymore. Sometimes the problem was fixed by resetting things via factory service mode, and other times the computer chip needed replacement.)
Posted on Dec 04, 2008
Need help connecting a funai dv220fx4 to a vizio m470vse?
Sounds to me like you got the component leads correct but not the composite (video).
See in the link for downloading the manual :-)
Funai 50 years of Excellence in Consumer Electronics
Apr 23, 2014 | Vizio L37 Television
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have a Vizio P50 HDTV20A. A couple of weeks ago our dvd player and WII system stopped working on AV1 or AV 2 - tv shows "no signal". The WII and DVD player work fine on other tvs. Before this...
Hi, if you plug up your cable box the AV1 does it still not work. Please let me know what you find out. If you take of the back of the TV there is a reset botton on the main input board. Thats the board where you hook up your devices too. Please let me know if that works or not.
Dec 06, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
I transferred some pictures from my computer on a Maxell RW disc. When I played the disc on my Funai DVD/VHS Dual recorder model DRV-2737 no picture appeared on TV screen. What could be the problem? On the...
sorry...it seem like your dvd/vhs player is outdated...(do the rw disc plays in pc?) are you using Nero software? this will curve the problem...or try another DVD RW brand that funai is compatible with...dvd players, dvd recorder and pc dvd burners do roll back...all must be a year or less apart to work with each other....
May 26, 2010 | Funai PY90VG DVD Player/VCR
Bought a Wii and using the standard cables it played great on a new 50' Panasonic Plasma as well as on our 2 year old 32' VIZIO LCD. Just upgraded to a 46' Sony LCD (W series) and the Wii looks terrible...
The Wii can display on a HDTV, but keep in mind the output is only 480p. It is not true high definition, and it will only display this using a component video cable. There shouldn't be a difference with LCD and plasma.
You will also need to go to the display settings to force the Wii to display in 480p.
Try a different input (safe to assume your Sony has multiple?) and see if it is that specific input. Also, try a different device like a DVD player or VCR and see if you get the same result.
Good luck.
Dec 07, 2009 | Nintendo Wii Console
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
No picture when playing a VHS tape
Nothing has worked! Talked with a tech on the phone line and she said unit is bad. Everyone seems to have problems with this type of unit period so I am returning it and giving up. Even the responses from others have not proved effective. Lousy product!
Jan 05, 2009 | Philips Magnavox DVD/VCR Dual Player
The DVD will play and display, but the VHS will play but not display.
It could be that the output to TV from VHS only works through the composite cables (the red, white, yellow).
Dec 11, 2007 | Samsung DVD-V8600 DVD Player/VCR
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
187 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
