Question about Proscan PS56700 56" Rear Projection Television
ProScan PS56700 completely out of focus / blurry
Someone gave me this Proscan PS56700 rear projection TV and revealed to me about the blurry image problem. I was told it was a simple part to replace but he cannot find the info on the part. Manufactured April 1999. Chassis # PTK195FP/F3P. Symptom - the image is so blurry, the menu cannot be read. Sound is fine, color seems to be ok. Don't know if it happened over a period of time or instantaneously but I imagine the prior owner just turned it on one day and this is the way it looked. Any direction or help would be appreciated.
  • TurboII Dec 05, 2007
    I have a PS56670 56" rear projection set mfg in 97. My screen has gone into a "fisheye" view after it warms up(about 20 min). Might be a similiar or same problem you are having.
    Top Expert:
  • Proscan Master
  • 29,399 Answers
I would replace the EHT unit as the focus voltage is supplied from there, if it has not been twiddled with by unskilled personnel.
Posted on May 08, 2017
SOURCE:
MikeNJ1964
  • 398 Answers
SOURCE: Proscan not turning on
Actually, the set has the PTK188AC chassis. This is a very uncommon chassis. The most common reason for the set not starting in that chassis is a shorted high voltage splitter. That is the large black box inside the set that has 5 thick red wires in it. When the set is turned on, the computer senses the short in the high voltage circuits and immediately shuts the set back off. When the set is on, that box has dangerously high voltage in it so it should only be replaced by a qualified tech familiar with the high voltage splitters in RCA projection sets.
Posted on Aug 28, 2007
SOURCE: ProScan Projection TV PS60690 shuts off
replace the small 5G5A125V fuse in the back where the power cord connects the to chip
Posted on Sep 02, 2008
SOURCE: Proscan Projection screen warped
Just had mine do this same thing today. Looks like its time for a flat screen. Sucks to spend the money though :(
Posted on Dec 22, 2009
SOURCE: i have a older proscan rear projection.. 60
volume will not come up--i have set the volume limiter all the way up,but it is still low. is there a setting in the back where i can set it up?
Posted on Jul 28, 2010
SD Tech
  • 14553 Answers
SOURCE: cobwebs proscan ps56700 inside screen
It can be done from the front but from the rear is actually more easy and safe--removing front screen and frame entails some danger of damage to the screens.
I have over many years of outside/home service calls encountered this.
As a outside technician I want the quickest and safest way to do this.
With set unplugged simply remove rear cover:
Use a swiffer type duster to reach up and inside and gently get all the webs out(do not use force when against the inside of the screens) and if the handle is long enough you will be able to remove all of the webs.
Also when doing this you will see with cover off 3 large black lens at the top of the chassis above the circuit boards.
They are the light source for your picture--clean them with a lens cloth or a paper towel with Glass cleaner sprayed on it---Do not attempt to clean the mirror in the rear as it is a film material and is easily scratched.
If the lens were dusty/dirty and then cleaned the picture will be brighter and sharper looking----that should be done about one time a year.
If you have questions make a comment here on this page(make a comment button).
Posted on Apr 21, 2012
How do I fix a convergence problem on a Proscan 50
I dont know how to fix it, only had the tv for 3 months already having problems doesnt say much for proscan!!
Nov 08, 2012 | Proscan PS50700 50" Rear Projection...
Cobwebs proscan ps56700 inside screen
Apr 21, 2012 | Proscan PS56700 56" Rear Projection...
No Picture
check your connection between digital box and yout tv replace it and try again then check input to be plugged good i mean ferm connection
Do that if your digital box work on other tv
Dec 10, 2008 | Proscan PS56700 56" Rear Projection...
PIONEER SD-P5185-K REAR PROJECTION TV
Bad convergence ic STK4277 I think. A qualified tech should be able to complete inhome for less than 300.00
Craig www.classtorations.com
Jun 06, 2008 | Proscan PS32500 32" TV
Feb 03, 2008 | Proscan PS50700 50" Rear Projection...
TV Did Not Turn On After It Was Turned Off
call tech ..suggest checking horizontal components.
Nov 26, 2007 | Proscan PS56700 56" Rear Projection...
Proscan s56700
call tech ...suggest checking horizontal drive.
Nov 12, 2007 | Proscan PS56700 56" Rear Projection...
Blurry picture and arched at bottom
We have a Proscan 50" Projection TV. A T.V. repairman told us it was the HV (Horizontal Vertical) Splitter causing this problem and tried to find the part for us. The part for our TV was too hard to find though and we ended up not having ours fixed. Our T.V. is 8 years old though, and Proscan is discontinued. Maybe you'll have better luck finding an H.V. Splitter for your TV. Of course, you'd need a professional to install it for you. Good luck.
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
112 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
