My split system is not working. I made a check with remote control and it give me code 16h. Someone tell me it is the outside board. I check it out and find that the compressor has some oil around. I want to know if the board is not working because the compressor have problems or if the compressor is not working because the board have problems.
  • 76 Answers
I thort that 16h was just the timer on split system airconditioners. meaning 16 hours till it will turn on.
If you have any questions please dont hesitate to ask
Posted on Dec 04, 2008
The outside unit leds have a 29 code, before it goes into shutdown. Outside is a LAU180HSV Invertor V Split System. Installed in 2012.
That code means that the compressor is drawing too much current when it is trying to start. It is highly unlikely that the main board is bad.
May 04, 2016 | LG Art Cool LA180HSV 18,200 BTU SingZone...
Tip
FI code check outside power supply board for blown capacitor
found blown outside board capacitor and part of the printed board strip burned off symtoms were fan would run for 1 or 2 min and then FI code
on Aug 31, 2013 | Amcor Aire AMS241HX Split System Air...
How to check MSG12HRN1W MINI SPLIT SYSTEM electronic board
If your mini split was installed to meet most building codes, an inside disconnect switch should have been installed. This switch breaks the power and signal from the outdoor unit to the indoor unit. It is not the same as the outside disconnect to the compressor (outdoor unit). If it was turned off, the inside unit would be dead. Look for a disconnect switch inside your room. By code is should be within 15 feet of the inside unit.
Nov 04, 2014 | Heating & Cooling
Remote control for Armstrong minisplit
You may be able to get any make of remote universal remote control and program it to operate your systems.
Mar 01, 2010 | RCA Universal Remote Control
Not working
If the circuit breaker tripped,then the unit is trying to work and the remote is certainly telling the unit operate, otherwise it could never trip the breaker if it did not receive a signal from the remote. Your problem may be with the outside unit that te compressor is stalled (having a hard time starting ) and this will cause the breaker to trip. You need a porfessional to diagnose if it is the starter control, or relay, or capacitor, or bad compressor, or bad terminals.
Nov 28, 2009 | Coffee Makers & Espresso Machines
Cannot set a/c to operate automatically
sound to be in heat modenow. If you are after the cool mode, then if you have a cool setting and a heat temp setting, Lower the heat to almost off and set the cool setting to 74 degrees. See if the outside coils get warm. Make sure you are off manualo and n auto. If it runs, give it some time and the tenp of the outside coil will rise and the inside will get cold. Food Luck
May 23, 2009 | Sanyo Split System Air Conditioner
Samsung inverter SH12VA1
standard is the pc board,propably the indoor,samsung has codes for the boards and put them with the remote control.call them and tell them the model to give you the code to rearrange the pc board.and its not to difficult to put the code with the remote control.
May 16, 2009 | Mitsubishi MS-A09WA Split System Air...
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
