Question about Technics SA-DX950 Receiver
Technics SA-DX950 has lost digital sound
I get no sound at all when turning to digital. The "test" button says it is operating normally. Analog sound works, but I have to turn the volume up high to get enough sound. Is this worth fixing?
  • rlaurenz Dec 05, 2008
    No sound at all, so I'd say clear. I can hear what sounds like a relay switch moving as I try to go from surround to the other digital options. I've turned everything else, including the tape monitor, on and off several times in a vain attempt to re-set something. I've also switched out the fiber cords to rule those out.
  • rlaurenz Dec 26, 2008
    You were correct about the problem being a powering issue. Here's the bill:
    Power Regulator Transistor - $12
    1 Diode - $6
    1 Register - $2
    Labor - $70.
    Works fine now. Does the bill seem reasonable?
    Habit-Forming:
  • 33 Answers
Did you Try the Help/Reset button on the Left side of the front panel, Push and hold it for 5-10 seconds then release.
I have had the same problem with mine when the volume is up too loud it will trip the reset.
Also Try a Different set of Fiber Cables "And" or a different input device (ie another player) to see if you get the same symptoms..
Posted on Mar 31, 2009
  • 4,234 Answers
This may sound like a silly check, but verify that the tape monitor switch is not engaged. What is the quality of the sound when turned up? Is the cound clear or raspy?
Thanks,
Dan
Posted on Dec 04, 2008
  • ABRsvcs Dec 05, 2008
    When in analog mode, the signal processing circuits are in "bypass" mode. If the analog mode produces a reduced sound level, I would suspect that the digital processing is either faulty or more likely, it is not being powered correctly. Check the low voltage supply for 12V and 5V and be sure that they are close to that value. Maybe the processing section is just loading down the signal.
    Keep me posted,
    Dan
  • ABRsvcs Dec 26, 2008
    The repair bill is reasonable and typical these days.
    Dan
Digital input glitch, switches randomly from analog to digital.
what connections do you use for the device you are listening to, and what device are you listening to when this happens. you should use either an analog, or a digital connection to a device, but not both
Mar 08, 2013 | Technics SA-DX930 Receiver
Technics sa-dx 950. F70 on display. ???
This is a shorthand version of protect. See the link below. If you have more questions, please post them here and I'll respond.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Aug 21, 2010 | Technics SA-DX950 Receiver
Technics sa-gx670 reciever sound drop
it could be that your amp chips are gettin hot
Jul 22, 2010 | Technics SA-DX750 Receiver
I have a technics reciver SA-DX950 when i tnru on it say F70 on the display
problem is oxidation...Remove and clean the ends of cables with sandpaper slowly...there is slim and flat cable into the reciver (together with five cable)...specially remove it's socket and clean it...
May 09, 2010 | Technics SA-DX950 Receiver
Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Feb 18, 2009 | Technics SA-DX950 Receiver
Technics SA-DX950 surround sound problems
The most likely culprit here is the output protection relay. The contacts are a little corroded and the higher volume "jumps the gap" temporarily "cleaning" the contacts. The relay should be changed. I don't have the manual with me, but the following relays are in the unit. One of them is the speaker relay:
Part # Cost
RSY0054-C $12.63
RSY0040M-0 $ 5.89
K6B2AHA00014 $ 8.14
Dan
Nov 12, 2008 | Technics SA-DX950 Receiver
Technics SA-DX950
sounds like the speaker protection relay is operating probably from a dc condition appearing on power amplifiers outputs. probable cause is dry solder joints to the output stages. will need some reworking of the PA stage soldering to fix.
Dec 10, 2007 | Technics SA-DX950 Receiver
F70 Error on SH-AC300
unit has a blown internal fuse. replace it with exact type of fuse and see what happens. if it blows again, it will need to be returned to a service agent
Sep 25, 2007 | Technics SA-DX950 Receiver
Technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Jun 25, 2007 | Technics SA-DX950 Receiver
Technics SA-DX950 Receiver Logo
371 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
