Question about Creda Europa E010E Electric Single Oven
Broken hinge on Europa oven
Need to find Australian parts distributor for Europa appliances
  • 68 Answers
Try Ausralian Bakery and Pizza, Equipment Importers
122 Whitehorse Road, Blackburn, Victoria, Australia. 3130
Telephone: +61 3 9878 6900
Facsimile: +61 3 9878 6966
They import Europa equipment
Posted on Aug 30, 2009
Need to remove the door, but my hinge doesn't look like the illustration in the manual
Open door alittle push down and pull out and up to remove door.. You may have to wiggle it a bit.
Hopes this helps Mike
May 23, 2015 | Thermador Ovens
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Oven door on a Amica upright oven not closing completely. Where can I obtain door hinges for a Amica Oven..it is still under warranty, less than 24 months old. I have tried a few spare part places...no one...
they are Australian company, What country are you in? The wesite for them is www.cimbre.com.au. I would need to know where you are in order to help you. Also need the model number. Usually manufactures warranty expires after 1 year
May 22, 2011 | Ovens
The door will not close and maintain a tight seal, what needs to be replaced?
these units have a door hinge issue, 99% of the time the hinges will fix the issue. Check the hinge receptacles the part the hinges lock into they often will go bad at the same time.
Order the hinges and replace them it will fix the problem. The link below is where we get our parts from.
Cheap Appliance parts
Good luck with your repair.
http://www.appliancerepairlesson.com/
Mar 05, 2011 | Jenn-Air Electric Single Oven
When oven is heating up a massive bang occurs. Sounds a bit like a gun shot. Also hinge on glass top are broken - where can we purchase parts to fix this.
The loud noise is either from sheet metal expanding under stress or an electrical arc. I recommend unplugging the oven, taking the back off, and inspecting the wiring to the oven heating element and the sheet metal near the wiring. Also inspect the plug and socket, oven control and the oven heater element itself for similar problems. If you see signs that arcing has occurred (burn marks, especially with melted metal), repair the wiring and reroute it if necessary to prevent arcing.
If you don't find anything, first make sure the oven rests firmly and levelly on all four feet to eliminate any twisting stress. If there is a problem here, the noise should go away after one or two more cycles once you fix it. A twist in the oven could have something to do with the broken hinges. In the worst case, you may have to loosen and tighten a lot of sheet metal screws to relieve stress in the assembly. It would best if you could locate where in the oven the noise is produced before doing this.
I was unable to find any reference to parts for your model. Please look for the model label either on the doorframe or inside the drawer under the main oven door and verify the complete model number. Also look at the hinges for a part number stamped on them. There are a number of on-line appliance parts stores that carry Dacor parts; you should be able to find something with a search for "Dacor" and the part or model number.
Jan 17, 2011 | Dacor ECS130 Epicure Electric Single Oven
FB 510 Cuisinair built in oven - how to replace door hinges and where can new hinges be obtained
Assume you have lifted the door off the oven. You may have to dismantle the door to replace the hinges. Take a hinge to an electrical appliance parts supplier to get new ones or ask stockist of this brand.
Jan 03, 2011 | Zanussi Ovens
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Door came off the hinge
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Whirlpool RBS305PDS Electric Single Oven
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Creda Europa E010E Electric Single Oven Logo
237 people viewed this question
Top Creda Ovens Experts
ashburton
William Robinson
William Robinson
Dan Webster
Dan Webster
Are you a Creda Oven Expert? Answer questions, earn points and help others
