Question about Brother Office Equipment & Supplies
Fax TN2920 asked for new toner cart put in but now says dust on drum?
Pulled out drum and cleaned it myself replaced and restarted. It worked!
Posted on Dec 05, 2008
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Open the front cover
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
  • Close the front cover
Hope this helps!
Vikroks
Mar 23, 2011 | Brother IntelliFax-2820 Laser Fax
How do you change a toner cartridge
Open up front op panel,mid door opens up tube sitting on top of drum unit is the toner cart! be care full can get messy!Pull lever on end of tube (will only go 1 way from original position)lift up and dispose of.pull white tape off of new cart install in drum push lever,open and close mid door a couple of times to cycle toner toner message will disappear.
Nov 23, 2010 | OKIFAX 4580 Plain Paper LED Fax
Just put a new toner cartridge in fax and now I get message saying "change drum soon" How do I fix this?
First make sure your toner cart is the right one for your machine.. Try another cartridge to verify that even though the cart is new does not mean it does not have a problem. I would check all the silver contacts on the drum unit to be sure they are clean. use 90% alcohol to clean them, using a cloth to wipe them.
Jun 08, 2010 | Brother IntelliFax-2820 Laser Fax
How do you change (where is it) the drum in the Okifax 5650?
rwhen you replace the toner youare putting it in the drum cartridge.the whole black unit gets replaced.lift it up to remove.when you replace it also install a new toner cartridge the drum resevoir will be empty when
new it will need a new toner cart. to fill it now you need to reset the drum counter.push select function
button,to the right number 8 or 9 says counter display
push it,screen will will say drum count reset? push yes arrow screen will say are you sure? push yes
tada! if it now says replace toner open the white cover
over the drum then reclose it a motor will run for about 30 seconds its adding the new toner to the
resevoir you may need to do this about 3 times or until add toner message goes away
Apr 20, 2010 | OKIFAX 5650 Plain Paper LED Fax
Brother HL-2040, The drum light keeps coming on and the left side of the printed page is all black?
Sounds like the toner cart. has toner packed at one end and possibly the drum cartridge is dirty. Remove both from the printer, separate the 2 and vacuum the drum cart. - them blow it clean. Run the drum wire cleaner (purple/blue tab on front edge of drum cart.) back & forth a number of times. Blow out the inside of the printer to get out toner dust. Reinstall toner back into drum cart, then hold GO/Control button down until all lights are on, let go, reinstall toner&drum back into printer, close door. Power down - then back on. That should do it. Worst case, you'll have to replace the drum unit.
Jan 07, 2010 | Brother HL-2040 Laser Printer
I just installed a new toner cartridge and now all my pages have a thick black line down the right side of every sheet.
the new cart mite be bad:(. Do you have a second cart? next cart placed in the machine properly? Look for a toner band on the drum?
Aug 13, 2009 | Brother IntelliFax-2820 Laser Fax
Clean Fax KXFHD351 Panasonic
Nope No mirror, try cleaning the drum corona wire. Gently clean wire with a #2 pecil eraser to remove any dirt, then open fax sheet feeder and GENTLY clean with alcohol wipe across the light bar scanner. Paper dust builds up on this.
Jul 08, 2009 | Panasonic KX-FHD351 Plain Paper Thermal...
I have cked all components....have cart and is not empty cleaned all i can.....my fax r too dark to read and the more i copy the darker they become.....HELP >:) Wm
What i have seen on other customers fax's that the toner cart. is bad. bot before you go put a buy a new 1. take the toner out of the drum unit, blow out the drum unit with can air or compressor, ( Do this out side or some place where toner is not a factore ) slide the blue or green slide lever move it back an Fourth bought 15 times put the toner back in, tray it, if not then tray new toner, if not then the drum unit, hope the cheaper works out for you
C.W.H.
Jan 29, 2009 | Brother IntelliFAX 2800 Laser Fax
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Dust on Drum message after installinng new Drum
Dust on drum refers to as you correctly stated the wire, it carries a electric charge that transfers the image. If the wire gets contaminated the electricity dont flow right so dust on drum is desplayed, you drum cart is faulty, they are not repairable items, go buy another then claim new/old one as faulty from them. Um aH.
Dec 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
