Question about Sharp AL 1631 Copier
Al-1631 Sharp copier
Machine will not make copy's. Paper runs thru,toner cartridges is new. There are not code's flashing. All looks like it is working properly.Some tell me that I need to replace the drum. The machine is about a year old but no where need 18,000 copy's were made. If it needs a drum I will replace it but just want to be sure. Thanks
  • 1 more comment
  • Debisue Nov 01, 2007
    I do have a broken corotron wire. Can you tell me if I can get a part or how to fix it. Thank you
  • Anonymous Feb 04, 2009
    VERY helpful. We would have never figured that out. Thank you!!!
  • Anonymous Mar 19, 2014
    I have a Sharp AR-163 Digital Laser Copier. I bought this unit second hand almost three years ago. It has worked great up to the last few weeks. When ever I do a copy I now get a shadow or repeat image on the copy. I think that this is likely to be down to low heat on the drum but I am not sure how to correct this problem. Is there any way to increase the heat or is it time for a replacement drum. Thank you for any help.
Hello. Thank you for your solution. Our copier suddenly gave only blank papers. We changed the toner cartridge, then pulled out the drum, at which point a think silver screen (mangled) fell out. Is this the tungsten wire you referred to above? If so, where can we get another...and where on earth does it go once we get a replacement? :-) Thank you for your assistance.
Posted on Nov 16, 2011
    Problem Solver:
  • 17 Answers
You could have one of several problems. Seeing as how you just replaced the toner, it could be a defective toner. Did you have the trouble prior to cartridge replacement? Did you replace it with OEM or after-market/refurbed stuff? You could also have a broken corotron wire. On the right side door is an assembly that has a very fine tungsten wire strung across it. This wire places a charge on the paper to "pull" the image off the drum. if it's broken, you will get blank (or almost blank) images). A 3rd possibility I have seen is that your scanner lock is on. Usually this will cause L1 codes, but I have seen cases where it didn't, and your scanner never moves from "home" position to scan your originals, again, resulting in no image being processed, and therefore blank copies. The scanner lock is under the scanner assembly (above the area where your copies come out) on the left side of the machine. It is a dial mechanism that can be turned to either the locked or unlocked position. It's hard to see, and you almost have to stand on your head to get a good view of it. It is not uncommon that in the process of removing copies from the "catch tray" area to accidentally brush it with one's hand, or watch, or ring, and spin it to the locked position. Certainly a bad drum can effect copy quality as well, but before spending the money, I'd check/re-check the other 3 first.
Posted on Feb 07, 2007
  • James Mastrine
    James Mastrine Oct 12, 2007
    I see you have marked the post as solved. I would be curious as to which solution you arrived at. Was it one of the items I suggested, or something else? Please let me know. Thanks.
    jim
    machines@mastrines.com
  • James Mastrine
    I'm just trying to get a gauge on just how helpful I've actually been to folks here over the last year.
SOURCE:
wheatlandsvc
  • 1110 Answers
SOURCE: sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Posted on Nov 16, 2009
Testimonial: "Ok sorry thank u. I am new sorry i will be better in the future."
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
Sharp Tech
  • 63 Answers
SOURCE: Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Posted on Oct 16, 2009
Testimonial: "Wow! A solution to my problem with a copier was posted within a couple of hours, and the procedure worked perfectly! Thanks. OB "
  • 990 Answers
SOURCE: i have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Posted on Feb 08, 2010
rezazadeh
  • 328 Answers
SOURCE: Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Posted on May 27, 2010
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
We have a Sharp Model AL-1631 unit that keeps running but doesn?t make copies. Any idea what is wrong and how to fix it? Thanks.
When these Sharp AL series machine just run and run it means they are low or out of toner. This is especially true if you are hearing a light thump thump noise while it is running. Just let it run and after 5 minutes or so it should shut down and then replace toner light should come on. This is the small red light that looks like a stack of 6 dots.
Either replace the toner or have your existing toner refilled.
Good Luck and Thank You for using Fixya.
Sep 17, 2010 | Sharp AL 1631 Copier
The copier never reaches the "ready to copy" state.
Do you have any flashing codes on the machine? I have seen empty toner cartridges with flakey chips on them cause that problem. Seems they run out of ink and the chip doesnt know what message to send and they just never come to ready.
Aug 19, 2010 | Sharp AL 1631 Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Nov 05, 2008 | Sharp AL 1631 Copier
Copier runs but copy is not made
please replace the toner cartridge.
sometimes it doesn't show that toner is empty
Apr 15, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
254 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
