Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
If i insert the flash drive into my system..but is vista....it will search for drive it wont get ...and i dont know what to do
  • 827 Answers
Try downloading the U3 driver, if you haven't already.
First plugin the sandisk to your usb port, and then check from Windows Explorer, does your sandisk cruzer detected? you'll get a new drive letter besides your local drive or named "removable disk".
If you do see it then just do format (you'll lose the U3), copy, store, overwrite it again and again as you like.
If you still need the U3 application, pls read this:
http://www.u3.com/support/default.aspx#CQ1
You possibly haven't installed the driver properly.
If a wizard that comes up as soon as you plug the device in, Just let it detect the device and then go to Control Panel, and System, and Device Manager, and double click on the device driver, or if it isn't there, double click on the unknown device with the yellow exclamation mark and hit the Driver tab, Install Driver, and choose the 'Let me choose the driver' option, and navigate to where you unzipped that driver you downloaded to, and click on the driver, wait for it to finish installing and reboot.
Let me know how you get on..
Good Luck!
Chris (ziraffa)
Posted on Dec 26, 2008
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
I am using windows vista, when i inserted my pen drive , it asks for drivers. the same pen drive,
Search for drivers in the Transcend website and install. Probably it should work. Thank You.
Oct 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to recognize the unrecognized flash drive?
Try this: Click Start > Click Run (In Vista, Start Search and in Windows 7, Search for program and files) > Type devmgmt.msc > hit Enter > Device Manager comes up > Scroll down to Universal Serial Bus Controllers > Click on the + sign in front of it > Right click and select uninstall all the USB Root Hub drivers > Restart.
Insert the Flash Drive and check.
Oct 19, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Farm on farmville (zynga games) will not load . . . mozilla foxfire . . . windows vista . . . adobe 9.3 . . . flash . . . system configure done . . .
Try downloading Google Chrome and install Flash again. If the browser wont load the game, system restore to an earlier date, and back up all the files you downloaded from the date your restoring your computer to, till today on an external hard drive/thumbdrive and run a virus scan and make sure you don't have a malaware virus.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 05, 2010 | Microsoft Windows Vista Home Premium...
Travel drive saying "insert disk"
let me suggest i ur able the flash drive icon when you go in desktop or my computer then right click on that drive and click the option format and follow instructions, if you are able to format successfully, then no worries if formatting is not done.....
ii) then try to keep your windows'xp or vista cd in the cd tray and restrat system and follow the procedure: formating system(dont wory im  nott going to install or reloading OS ), when u reach a position where u see all the partition(like c, d ,e drive ... with memories), u will also see the flash drive partition along with hard-disk partion separately...
now click on the flash drive partition and press the button D to delete partition and follow instruction after do this , press C to create partition and u will see that a letter(e, f..) will be given to our flash drive....
now quit xp (by pressing ESC, donot proceed loading XP or vista) and now restart system and i think ur flash drive will work.....
Dec 31, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
My 8gb micro cruzer flash drive has been unformatted.
i)let me suggest i ur able the flash drive icon when you go in desktop or my computer then right click on that drive and click the option format and follow instructions, if you are able to format successfully, then no worries if formatting is not done.....
ii) then try to keep your windows'xp or vista cd in the cd tray and restrat system and follow the procedure formating system(i'm not saying to install or reloading a pc), when u reach a position where u see all the partition(like c, d ,e drive ... with memories), u will also see the flash drive partition along with hard-disk partion separately...
Dec 30, 2008 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I don't know a thing about it.
When you insert the flash drive into a USB port, the system will (okay, should) recognize it as a "removable" drive. It will assign a drive letter to it, which you can treat as a regular hard drive.
So, plug it in, then open My Computer, and you should see it there. Save to it, delete from it, whatever you want. If your system is not recognizing it (XP and Vista should do so, automatically), then you may have a flash drive that requires a driver (typically, SanDisk units do not).
Cheers
Nick
Dec 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Usb port
ive got a flash drive that does the same thing ,,one day it does ,one day it dont,, do you have vista or xp ,,because i think its got somethin to do with vista ,,and some of them flash drives,, goodluck
Aug 25, 2008 | Compaq Presario Notebook
Sandisk 4GB cruzer micro usb flash hard drive
try removing off the launchpad program from the pen drive through an XP system with this software and then try inserting it on the vista as an ordinary pen drive.
Mar 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Lost installation disk.
Helloo
I Dont Think Anyone Gets An Installation Disc With A ROM
Wierd..........
Anyway U Should Just Plug It In (The Drive) And It Should Plug and Play Function. If You Are Running Vista or XP
OtherWise If A box Appears That Cannot Locate Driver Or Insert Installation Disc Like In Vista Just Browse My Computer From There and Put This Address to Search - YOur Win Drive
ex -: C:/Windows
And Search All Drivers Should Get Installed IF This Doesnt Work Just Comment Or If U Dnt Understand Just Comment On This I Have Some More Solutions...................................................................
Good Day.
Jan 13, 2008 | KHypermedia (KDVRW8X) (20730176) DVD+RW...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
79 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
