Question about Kodak I280
Stops scan with the flatbed after tree o forth pages
When use de flatbed, Stops scan after tree o forth pages and the red led is on.
    Novelist:
    Champion:
  • 202 Answers
Try downloading and installing new drivers. You should checkout the machines timeout settings. See if there is a way to set the machine to default settings. Is the machine showing any signs of excessive heat? Is the machine getting time to reset before next scan is sent? The scanners memory may not be clearing to allow room for the new job and just halts. Try a fresh install of the scanner with the newest drivers. Good Luck, Tim
Posted on Feb 21, 2007
SOURCE:
I get a red line down one side of the page when scanning using the adf on a HP 5590 scanner
My guess is the ADF has picked up some dirt. Check the path very carefully.
Nov 04, 2011 | HP Scanjet 5590 Flatbed Scanner
Begins scanning...then stops in middle and won't complete scan. I'm in windows 7 with HP Scanjet 5590
Go into your "printer properties" and make sure that someone hasn't inadvertantly changed the page settings.
Oct 05, 2009 | HP 5590 ScanJet Flatbed Scanner
Adf does not scan all pages
Try cleaning the rubber rollers in the ADF
S. Mohan
Sep 29, 2009 | Ricoh IS 450DE VRS Flatbed Scanner
Not scanning full page
You omitted some details which might help diagnose the problem. For example, are you using the document feeder or the flatbed? Anyway, I'll take a guess here.
Check your paper size setting and make sure it matches the sheet you are scanning. (Letter, A4, Legal, etc.)
If this is not it, then try scanning from both flatbed and feeder and see if results vary. Note that when you use the feeder, scanning is done in a smaller window to the left of the flatbed, so make sure that is clean.
Mar 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Green layer on scanned image from ADF Simplex
What model of scanner are you using? Is it white light based or RGB LEDs (Light Emitting Diodes). Very rarely it may happen that the Red and Blue LEDs are not glowing may be because of loose contact, but this very rare occurence. Try reloading driver software.
S. Mohan
Aug 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
Canoscan 9950f red line on scan
Try running a calibration. This is done thorugh ScanGear in Advanced mode. Once in Advanced Mode, in the Image Settings section there should be an option for Calibration (you may have to scroll down in this section to see it). After running the calibration, try performing a preview scan with nothing on the scanner glass. If the red line shows up on the preview now, then most likely the scanner needs to be serviced.
Mar 12, 2008 | Canon CanoScan 9950F Flatbed Scanner
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Awful noise
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (the plastic switch at the back of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Oct 16, 2007 | Epson Perfection 4180 Photo Flatbed...
Kodak I280 Logo
74 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
