Question about Panasonic PT-61HX40 61" Rear Projection Television
Skt IC and Capicitor??
I read all solutions.. but still dosen't understanding.. please help.. i have panasonic PT-61HX40 year 2000 model it had blue ghost image, specially right side top to bottom is kind wave with blue color. entire picture had ghost image. when i open back panel and covered blue crt then picture were great. some people said need to replace skt IC and capicitor, but i don't know what IC's and capicitor need to be replace..i have no service manual. please give me a advise to fix this problem.. and Thank you very much!!!
  • 203 Answers
You need to replace both STKs. They are pretty obvious to find in the unit. They are normally mounted to the same heat sink and will typically be about 3 inches long each, maybe 2 or so high...Front should read something like STK350-120
Posted on Jun 08, 2007
Need to know how to install lamp
Your set does NOT use a lamp--it has picture tubes, and if no pix--may have lost one or more convergence chips.
Mar 29, 2014 | Panasonic PT-61HX40 61" Rear Projection...
Powers up then shuts down within 5 seconds? Power supply board? How much to repair?
MAYBE...A POWER SUPPLY BOARD REPAIR CAN COST YOU MAYBE $300-$500. OR MAYBE A FEW CAPACITORS..SMALL REPAIR. AFTER 13 YEARS, IF IT IS THE POWER BOARD, YOU MAY WANT TO INVEST TO A NEW MODEL.
Jan 31, 2014 | Panasonic PT-61HX40 61" Rear Projection...
Installed a comcast digital box on the panasonic tv and
Go in menu goto setup pick ch.setup pick cable rescan all channels
Jan 13, 2010 | Panasonic PT-61HX40 61" Rear Projection...
Replace IC Convergance chip in Panasonic PT-56HX41PF
If you are talking about removing old ICs use a cap of Alcohol to pour on top to loosen. Or use needle nose plyers to pull from hole on top side of ic s.
Aug 21, 2009 | Panasonic PT-51HX41 51" Rear Projection...
MOVED TV NOW NO PIC JUST RED BLUE GREEN ON TOP HALF OF SCREEN
Try re-soldering convergence IC pins first, they might get loose when you moved the TV.
May 27, 2009 | Panasonic PT-61HX40 61" Rear Projection...
Where can we get the best IC Replacement
always stick with the manufacturers brand ! but you will need to check the resistors on the IC lines to make sure thier values are not off , because that will cause the IC to go again no matter what brand IC you use. other components in line of the IC should also be checked for bad values as they can also cause malfunction and breakdown of an IC and its circuit components
Dec 30, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-61HX42F turns on, but wont stay on.
you need to change the stk 392-110 (2 ic ) and some resistor around the area ok
Sep 08, 2008 | Panasonic PT-61HX42 61" Rear Projection...
Panasonic PT-47WX53 does not turn on
Yes, I did try to use the power button on the TV itself. That did not work too. Yes, there is blinking red light too. I searched through several sights and found out that it is an issue with the IC 4511. I could not find a place to buy the chip.
By the way, our local TV dealer asked for $400 to fix this issue. I had already spent $400 on a different repair on this TV, 6 months ago.
Any suggestion/advice would be very helpful. Thank you again for your response.
Feb 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Blue convergence will not move left or right
look at the convergance board it will be the one on the left there re two stk semi-conductors tward the back of the board. most likly one of them are bad but sometimes the soldering can be faulty. look for signs of cold solder if so just resolder and should be good if not also look for burnt resistors. it will be obvious finding the stk 's can be done by using google and just type in the stk # finding the resistors you might try calling panasonic to find the part #by telling them the location of the burnt resistor. good luck. mind you that the soldering of the stk (semi-conductors) you will want to use a heat sink on each terminal you solder otherwise you take a chance of burning the conductor befor you ever get to use it, if you have no exp. soldering i wouldnt sugest trying it !!!!
Oct 17, 2007 | Panasonic PT-61HX40 61" Rear Projection...
Clean inside of the screen? Spider webs?
You should get the service manual so you dont take apart something you shouldnt
Aug 24, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Panasonic PT-61HX40 61" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
