Question about Casio G-Shock G7000D-8V Wrist Watch
Need to set time on casio wave raptor
Bought boyfriend a new battery for watch. Of course he did not save instructions on setting time...
SOURCE: casio wave ceptor wvq 202hdu ibver
I don't have wvq 202hdu but I have a waveceptor that had the same problem. After not being able to find a solution online, I went back and started playing with it and I figured it out on my wva-430a. Hopefully my instruction helps:
The problem is that the daylight saving time is set to ON (or maybe OFF) whereas it has to be set on Automatic (A). To change that on my wva-430a, I held the "Adjust/Display" button for three seconds. It showed "US 60" for me. Then I used the "Mode/Select" button to go to the next screen which shows CHI for Chicago (Central Time). Here you have to choose the city that corresponds to your time zone. Again by pressing "Mode/Select" it took me to the next screen which was the daylight saving option. The choices were ON/OF/A that could be cycled by pressing "Receiving/Set+" button. Set it to "A" for automatic. Then press Adjust/Display to see the last option for 12H/24H setting. Press Adjust/Display one more time to go out of the settings menu. Your watch should adjust itself immediately.
Posted on Nov 07, 2007
SOURCE: Watch adjustments
An even better website for Casio Manual Downloads in PDF Format is: http://world.casio.com/wat/download/en/manual/
Just enter the 3 or 4 digit module number in the box on the back of the watch & up comes ALL of the Operating Instructions!!
Posted on Jun 11, 2008
SOURCE: casio wave ceptor WVA-105H
Casio is a great watch company
you can get online manuals anytime
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2734&submit.x=49&submit.y=8
Posted on Nov 10, 2008
escapement
  • 2334 Answers
SOURCE: new battery can not reset watch CASIO #2735 Atomic wave ceptor
Did you try this?:
Rate, please.
Posted on Mar 28, 2009
SOURCE: hi i have mislaid my
Try this link:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3749.pdf
Posted on Apr 19, 2009
I have a Casio Wave Captor 4757 WVQ-142E and after the change in time this fall I can't seem to set the time correctly. I am in Paris, so GMT +1, however it is 10:30 and my watch reads 3:03. I have reset...
I sympathize, it took me ages to work this out - I had the same problem having had the battery replaced in my watch which only lasted 18 months...the irony was that my previous watch was still working & set to the correct, time date etc!
The following instructions are for the Casio Wave Ceptor 4757 WVQ-142E, the official Casio instructions are available at the following:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4757
For the extra information Casio neglect to tell you in the manual, read the following:
First, the watch needs resetting. To do this you need a watchmaker's screwdriver, remove the back (4 screws - obviously, you do this at your own risk), remove the thin plastic cover to reveal the battery.
On my watch on the battery cover it says to reset the watch, get a pair of tweezers & connect the battery back to the negative (marked -) plate for about 2 seconds, thus forming a circuit.
The watch stops, the screen goes blank for about 30 seconds, replace the plastic cover , back & screws.
Wait until the watch has picked up the correct time signal, the digital part will show the correct local time, the analogue screen won't at this stage.
Set the watch to the desired time zone that you require or HS (Home Setting).
Then press button "C" (bottom left) to scroll through until "HS" is displayed on the screen, then press button B (top right) for about 5 seconds until it flashes "OO" in the screen, then press the A (top left) button down & to reset the analogue time (so all 3 hands are pointing up) to 12 O'clock, it has to be set to 12 so the watch will recalibrate itself, if it is not set to 12 O'clock, it won't work! - sadly Casio don't tell you this bit in the manual....& of course this is really obvious to us mere mortals!
Now that you have aching hands & repetitive strain injury, press the B button (top left) to exit the (watch) hand setting mode & the watch will now wind the hands by itself to the correct analogue time, (or in theory it will, it took three attempts to set my watch).
Yes, for the record Mr Casio, if you hand a watch to someone & tell them to set it to the correct time, they will set it to the current local time (assuming that it is not 12 O'clock) & as opposed to 12 O'clock by default!
This is not rocket science, if your company is able to make & market a radio controlled watch which is in theory accurate to one second in a million years because it is controlled by the Rugby atomic clock, you'd think that the instruction department could write some decent instructions!
Hopefully this solved the problem!
Nov 02, 2010 | Watches
I need instructions on setting the time on my Wave Ceptor 4756 142A. Recently replaced batteries and lost manual.
browse through my tips and you will find link for all Casio watch manual downloads.
Sep 28, 2010 | Casio Watches
My wave cepter wr100m recently had the battery changed and now the time is completely wrong. I have manually setting the time but the hands are still showing the wrong time (it's out by 6 hours 23 mins).
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box.
Aug 19, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Lost the manual. Son reset watch. I've reset the
go to www.casio.co.uk go to support(methinks??) click on watches and put in the model number (the one you posted) and download the PDF manual relating to your watch (you will need adobe reader free download to read PDFs), this will be the full manual, once you figure it out DST will have to be on, as its summertime of course. ( i bought a wave ceptor for a fiver because the guy who had it didnt know how to recalibrate it after a battery change), a quick gander at the online manual put it right, there shouldnt be a problem setting it up again, good luck
Aug 05, 2009 | Casio Wave Ceptor Watch WVA510A
Cannot reset time
Hi to anyone with a wave ceptor, when you replace a battery you need to re calibrate the hands to 12 o'clock (also those with a 24 hour hand will need to be set to 24) this is called the home position, the same goes to stopwatch hands.
The hand setting settings vary wildly from watch to watch you will need to consult the manual or if you have lost it download thePDF file from casios support page, www.casio.co.uk , you will need adobe reader or a similar program that reads PDF files also you will need the module number, this can be found as a 4 figure number on the back of the watch, these instructions are easy enough to understand, i managed to set mine no problem.
Good luck!!!!
Apr 18, 2009 | Watches
Battery replacement for casio wave ceptor wvq-200hu WATCH
Download abridged instructions from casio @ http://world.casio.com/wat/download/en/manual
Apr 05, 2009 | Casio Waveceptor Atomic Radio Controlled...
Do not have the manual to wave raptor wva-106hr
Paste this link into your brouser and follow instructions:
Do not forget to rate, please.
Feb 04, 2009 | Casio Wave Ceptor WVA104HLA8V Wrist Watch
Setting my watch
Hi go to www.casio.com/support under technical support choose manuals.
Nov 14, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Instructions for casio wave ceptor 4303
Managed to set the home time - through trial and error.
Left it at the window for a few minutes and VOILA - the watch did the rest.
MAGIC!
It keeps time perfectly.
Jun 07, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio G-Shock G7000D-8V Wrist Watch Logo
240 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
