Question about Toshiba Satellite A135-S4527 Notebook
Windows fail to open
There are some files corrupted, windows do not open.
  • 1 more comment
  • ja.net May 11, 2010
    no can you send me a copy of the disc?
    no can you make me a copy and send it to me
  • Joe May 11, 2010
    Do you have the original install disc?
  • 520 Answers
You need to install or repair os
no options.
need to how just ask
Posted on Jan 06, 2009
Folder Corrupt and Trying to Install Adobe Photoshop Elements 9
First variant you may use if your .psd file was seriously damaged
https://www.repairtoolbox.com/photoshoprepair.html Photoshop Repair Toolbox
Second solutions are showed as knowledge bases about Adobe Photoshop
http://www.techrepublic.com/forums/questions/repairing-damaged-adobe-photoshop-psd-files/
https://forums.adobe.com/message/6698481
Third one is a guide from Adobe
·Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
·Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
·Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
· Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name
Sep 16, 2015 | Adobe Photoshop CS for PC
How to view corrupted rar?
RAR is the native format of WinRAR archiver. WinRAR tool is not only used to create RAR file but also used to repair corrupted RAR file or fix corruption from them. Whenever WinRAR fails to extract data from RAR archive, it means the archive is invalid or corrupted. You can repair the corrupted RAR archive by using the built-in repair feature of WinRAR application. All the required steps are shown below:
Solution #1
1) Open your WinRAR application.
2) Click on File tab and then click on Open archive. Or simply press Ctrl+O.
3) A new small window "Find archive" will be appeared.
4) Now locate your corrupt RAR file from the system directory and then click on Open.
5) Click on Tools tab and then click on Repair archive. Or simply press Ctrl+R.
6) Again a new small window "Repairing FileName.rar" will be appeared.
7) Now Browse the location where you want to save the new repaired archive.
8) The box "Treat the corrupt archive as RAR" is checked by default. But if it is not, then do check it.
9) Click on OK. The repairing process of selected archive will be started.
10) Once it is successfully completed click on Close.
Solution #2
RAR Viewer Tool - http://www.rar.viewertool.com/
May 06, 2015 | RARLAB WinRAR
How can I open invalid .zip archive?
if you have tried 7z,zip,rar make sure all of them are the latest version. many zip files are compressed with rar 5. and you have to have winrar 5.x to open.
Mar 02, 2015 | 7-Zip Software 7-Zip x64
Adobe illustrator file corruption. What to do?
First check your illustrator. Could it open other files or not? Try to create new file and save it, then open again.
Try to open your corrupted file on another PC. Then if it doesn't work, it means that your file is corrupted. So you should try to restore it by Recovery Toolbox for Illustrator . You can download it here http://www.illustrator.recoverytoolbox.com/
Also you can read here about corrupted file recovery: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/513-adobe-illustrator-file-corruption
Nov 18, 2014 | Adobe Illustrator CS3 - Windows for PC...
I have .BKF file that I cannot open with many of my files. What can I do?
If you are finding a good solution for damaged BKF files, then you can try third party BKF recovery tool http://www.recoverfilesdownload.com/bkf-recovery.html It is capable to recovering your data from damaged backup files without hassle. BKF Recovery Tool to Recover Corrupt MS Backup BKF Files
May 24, 2014 | SimpleTech Signature Mini 160GB External...
Corrupt excel sheet
MS Excel comes with an automatic recovery feature that attempt to reopen corrupt excel file along with repairing a file. If it fails to repair a corrupt excel file then try to open a file without repair. Sometimes this automatic recovery feature fails to open & repair corrupt excel files at this stage users can repair corrupt excel file manually.
To Manually Repair an Excel File: For manual repair of a corrupt excel file, you have to perform following steps:
  • Go-to the File Menu & click on 'Open'
  • Now select the file that you want to repair and click on the arrow next to 'open' button.
  • Click on 'Open & Repair' & any one method that you want to recover your data.
Source : Link
Jan 16, 2013 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I feel my is too slow when i start.. even if i click any buttons or in screen then it vl go to not responding state.. after a lot of time back , it will come to normal.. it takes time atleast to open...
ok one possible cause is the corruption of the system, if your windows was been failed to load before and you have just reset it or pressed the button to turn it off, then their is a big chance that the system file of your windows might be corrupted. Try to run chkdsk under safemode environment. Type on RUN>CMD>under CMD environment type CHKDSK /R wait until it finish, it takes a while to finish because the system is trying to fix lost clusters or corrupted files. Hope it helps thanks.
Sep 16, 2011 | Computers & Internet
Computer turns on but will not load windows. Freezes after gateway comes on. Plus cannot start in safemode
Enter the BIOS and ensure that the Hard drive is indeed being seen by the computer.
Open up the chassis side panel and ensure that all conections are making contact.
damnor01
Apr 14, 2011 | Gateway 3250S PC Desktop
I have Adobe Photoshop Album Starter 3.2 but I now cannot open any of my thumbnail images as they are all described as 'missing files'. I have searched throughout my computer but have failed to find them....
This is due to file type was corrupted, Open the images by selecting 'open with' option and select the proper application to open the same will resolve your problem. or open windows explorer>Tools>folder options>file types tab> select the file extention and select proper application in open with option.
Dec 08, 2009 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
