Question about Ovens
Need to replace bulb in GE advantium oven SCB2001FSS.
I need to replace the internal bulb in my GE advantium oven. Are there written directions so that I can avoid a service call and do it myself?
4 Suggested Answers
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Posted on Apr 06, 2009
woobie dog
  • 1273 Answers
SOURCE: Our GE Advantium oven is Flashing F-3
F3 is the error code for control panel failure. A replacement costs~$200. In reading the literature, some people have had temporary success by depowering the unit, removing the ribbon cable to the control board, and cleaning the connections with a pencil eraser. This has bought some people several months of time, some none.... Once ordered, the part usually arrives in several days, and swapping it out isn't hard, once you get to the card.
Hope this helps, --W/D-- please feel free to rate this solution.
Posted on Jul 30, 2009
Turned off breaker for 30 seconds. Display returned.
Posted on Jan 20, 2010
Do you have any directions to replace the upper heating element for a GE profile Advantium 120 model SCA100DBB93?
Hey Mary Lynn, .. with that unit not being manufactured any longer, it might be time to upgrade..IF you want to pursue replacement.. try here...
Ge Advantium Microwave Parts Fast Shipping RepairClinic com
Jun 19, 2017 | Ovens
My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
GE Advantium SCA1000DBB03 handle replacement
open door look at side there some are some screws remove them the outer door part will come off now don t be afraid to use screwdriver to help take it off good luck later
Apr 01, 2009 | GE SCA2001FSS Advantium Electric Single...
Need to replace halogen bulb that illuminates Advantium interior
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Feb 17, 2009 | GE Profile Advantium SCB2001KSS Stainless...
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
Ge profile advantium 120, scb1001 oven, display panel out
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
GE Profile Advantium oven (stainless steel)
spray a little oven cleaner on a wet rag and wipe. Rinse really well afterwards. Do not spray directly in oven. It could get in the holes.
Jun 10, 2008 | GE Profile Advantium SCB2001KSS Stainless...
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
How to replace the oven sensor
order your sensor from local supply house, 2 screws inside oven cavity, any luck itll pull right through and you be able to re=plug the new one, if not remove the back panel and unplug it from there2 screws nad one plug no prob at all
Feb 24, 2008 | GE SCB2001FSS Advantium Electric Single...
Advantium oven has no power
THE NEXT STEP IS TO CHECK THE OUTLET FOR POWER, THEN THE CORD WHERE IT ATTACHES TO TO OVEN ITSELF. A VOLT METER IS MOST RECOMMENDED FOR THIS, AS THERE MAY BE A BURT WIRE OR BAD PLUG.
Nov 15, 2007 | GE SCB2001FSS Advantium Electric Single...
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
