Question about Pentax AF-330 FTZ TTL Flash
Pentax AF330 Ftz Flash
Will this unit work with a Pentx 200D Camera
3 Suggested Answers
  • 2976 Answers
SOURCE: i have a plan to get PENTAX AF 500 FTZ flash. i
Check the configuration of the hot shoe on the flash AND the camera. The only issue you should have, is setting up for the heat range and the syncronizing speed.
Posted on Aug 10, 2009
  • 11967 Answers
SOURCE: Pentax istd flash has stopped working
Flash tube is probably burned out.
Posted on Nov 22, 2009
Is it OK to use a Pentax AF500FTZ flash on-camera with a Nikon D70s? Is the trigger voltage going to be a problem? It looks like one can use a Nikon flash on a Pentax DSLR without problems.
The brands use the flash contacts to communicate to the camera. They do not make their flashes compatible with other brands. Don't mix brands. Even if trigger voltageis not an issue, the TTL and AF is not going to function.
Mar 24, 2011 | Pentax AF-500 FTZ TTL Flash
Pentax k-m not recognized in iphoto
I'm unfamiliar with iPhoto, but if it's fully up to date and still does not list the Pentax K-M then see if it allows you to manually select the Pentax K-200D.
As the K-M is essentially a budget variant of the K-200D it may solve your problem.
If not, then hang on a bit longer and someone who is familiar with iPhoto may see your question and be able to provide a more accurate answer.
Jan 18, 2010 | Pentax K1000 35mm SLR Camera
I have a plan to get PENTAX AF 500 FTZ flash. i have a doubt if this model will be fine working for my sony alpha 200 DSLR. kesavan b
Aug 10, 2009 | Pentax AF-500 FTZ TTL Flash
Can i use this flash with a nikon d60?
No you must use Nikon compatible flashes with Nikon cameras. Pentax flashes only work on Pentax cameras. There is no adapter to make it work either.
Jun 24, 2009 | Pentax AF-330 FTZ TTL Flash
I want know the price of PENTX OPTO E 40 . Price in indian currancy. thank you
Dear BPrakash1968,
Although the exact price in India is not known however I saw a gentleman quoting a price of Rs7000 for this model and he says that its "brand new camera" (in his terms). The link is:
http://mumbai.olx.in/pentax-optio-e40-8-1-mp-digital-camera-iid-11008392
As he is selling it for secondhand.. the original price should be somewhere around 8500 to 9000 .. that's my guess.
Hope that helps.
Regards,
Srinivas
Jun 19, 2009 | Pentax Optio E40 Digital Camera
Can Film Camera lenses and Flash be used for Digital Camera Body
If u used to have a Pentax camera, i would recommend you buying a Pentax DSLR, because Pentax film lenses still works on Pentax DSLR. I still use some of my prime lenses on my K10D.
Jun 05, 2009 | Pentax MZ-60 QD 35mm SLR Camera
Washed out pictures using a Bower 724 AFPX flash
This is probably not the camera settings. Pentax k200D wilt only give auto-flash with just three of their own units. Sounds like you have the Bower set on Auto. Set the flash to Manual, and adjust exposure on the aperture setting with the body set to manual as well.
Note that several people have reported problems with Bower units on digital cameras (and not just on Pentax)
Mar 22, 2009 | Pentax K200D 10 Megapixel Digital SLR...
What is the trigger voltage for Pentax AF 500FTZ
When using a digital camera with a flash unit of unknown trigger voltage, you are risking the life of your camera. Excessive trigger voltages can disable the cameras internal circuitry to the point where it is totally beyond repair.
I do not have, in my files. the trigger voltage for the specified flash unit. I only have the specs for larger portables and studio flash gear.
A simple test , however, will reveal the exact trigger voltage. If you have a multi-meter or a DV voltmeter with a 250 VDC range (just to be in the safe side) you can preform this test at home or an electronics service technician can do it for you in a few minutes.
The test lead are placed across the synch contacts on the foot of the unit or plugged into the sunch socket if the flash unit has one. If the reading is more that 4 or 5 volts you can still safely use the flash with the aid of a protector device which goes in between the flash and the camera. Theses are available at better camera shops and dealers.
Ed
Nov 16, 2008 | Pentax AF-500 FTZ TTL Flash
Pentax me super camera
Hey judyrosebudd,
You should be able to use any flash that is not dedicated to another camera manufacturer. Even though the manufacturer lists this camera as a dedicated flash unit it still has the sync contact in the center of the hot shoe mount, which is all that is required to operate a all manual flash. This being said a dedicated flash should provide much more advanced options and simplicity of use. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 22, 2008 | Pentax ME Super 35mm SLR Camera
K100D flash doesn´t work
My camera with the dodgy flash is holidaying in Japan as they sent it to be fixed - not sure how old your camera is but I am trying to see if this is an issue that occurs with the camera model.... given that there are only two of us to date I am thinking that we may have just struck the jackpot :(
Dec 27, 2007 | Pentax K100D Digital Camera
Pentax AF-330 FTZ TTL Flash Logo
77 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
