Question about Sanyo DWM-2600 System
Black and white screen
I recntly bought a used toshiba tv and when i connected my dwm-2600 system to it, the picture is only in black and white. but when i connect my PS2 to the same rc plug ins, everything looks perfect. all the settings seem fine on the tv. so i connected my dwm-2600 to 4 other tvs and it works good. i know the person i bought the tv from and i know it was in great condition. do you think it could be a compatiblity issue. please help, my PS2 doesnt play dvds as well as the dwm-2600.
4 Suggested Answers
SOURCE: DVD won't play: Err message
We have the same problem with our Sanyo DWM-3800.
Kal
Posted on Dec 20, 2007
SOURCE: Sanyo DMW-3800 system problem
call jinnie at sanyo
ph # is 870-633-5030
for the 9 pin cord from unit to subwoofer
Posted on Jan 05, 2009
EarthJam
  • 23 Answers
SOURCE: No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Posted on Feb 03, 2009
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
Hey i just bought an atari 2600 and when i turn it on with the color switch on, it still stais black and white but the tones of the black and white are diferent from the black and white option, can someone...
Is this an NTSC compatible TV? The result you describe is what can happen if you try to use an NTSC Atari on a PAL TV. The color signals are different.
Jun 18, 2011 | Atari 2600 Console
Toshiba 40RV525U. I bought it in Canada and now live in South America. With Antenna now the TV works just in Black & White (without Colors). I can not find where tu change NTSC / PAL (The TV does it...
Well, unfortunately your TV supports only the NTSC System, while the most of South American states are using the PAL TV System.
Your only chance is to connect a TV tuner supporting both system to make the conversion between the systems.
May 03, 2011 | Toshiba 40RV525U 40 in. LCD TV
What is the problem with a toshiba flat screen tv that can only be viewed in black and white? Cycling on and off sometimes produces a color picture.
check your tv manual..is your tv is a multisystem?select the system that is compatible to your local tv system.whether it is PAL.,NTSC,PALSECAM.and others..
May 17, 2010 | Toshiba 32A33 32" TV
Atari 2600 does not have picture when turned on.
I just got a Atari 2600 as well and can't get it to produce a picture. The transducer and the chips are getting warm when I turn it on, so I know it is getting power. I have tried to clean everything with rubbing alcohol but nothing has worked so far. I have also tried about 7 different games all do nothing.
Is there some part or component that commonly goes on these systems? I have a friend who also bought a 2600 and he is having the same problem.
May 27, 2009 | Atari 2600 Console
Need help w/ computer hook-up
Check if your laptop has a S-Video connector. If so, a direct S-Video cable should work.
Nov 22, 2008 | Sanyo DWM-2600 System
HOME THEATER CONNECTIONS
I get all the sound I need but I can't play the TV through the sound system. It is a samsung DB390. Can play DVD's through the system but not the TV. Any ideas?
Roger
Feb 17, 2008 | Sanyo DWM-2500 System
Atari 2600 fuzzy screen
Hello, Are you using a newer flat panel or and older TV? IF you are using a newer TV the picture will never look very good. IF not, did you try working with the RF adapter? Check all connections. If all else fails try to get another RF adapter to see if that helps. I remember this being a bit problematic even when these were new. Wish I had a definite answer for you! Good Luck - Dr. Know
Dec 23, 2007 | Atari 2600 Console
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Sanyo DWM-2600 System Logo
43 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Frank Russell
Frank Russell
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
