Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura capresso shuts down
My S8 turns itself off, as if a circuit breaker in the machine just "trips" and the machine shuts down, just as if the electrical supply cordwas unpluged. The machine is not shutting down with it's normal timed rinse and power off method as it should be doing. It is not the ground fault of my homes electrical outlet. Anyone had similiar trouble?
    New Friend:
There's one connection on main board on back of unit that causes a overheating problem.You may find that the wire going to it has discolored.
Solution:Change wire or connector.
Posted on Jan 05, 2016
    Problem Solver:
  • 16 Answers
It is possible that the timer unit in the maker is defective and need to be replaced. I would suggest you move the coffee maker to a different outlet and see if you have the same problem. If there is a short in the mechanism or a bad connection in the timer it could be experiencing a thermal shutdown.
Posted on Oct 12, 2010
Jura impressa s8, the display shows" please wait" and doesn't switch to the Coffee Ready.
This error is because:
1- Flow meter is blocked & not sending signal of water flow.
2- Entire hydraulic system is filled with Calcium deposits and slowed down flow of water.
Solution:
1- Open the machine and manually clean flow meter. It is located between the water tank & the pump.
2- Follow this by manually descaling the machine. Seelink. Do not use automatic descaling method suggested by Jura.
Stop using Filter cartridges as the machine reminders for descaling are silenced by use of filters. Services Unlimited Inc Parts Guru Since 1988
Apr 22, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Press steam fill water
You can check the water valve, it may become clogged. But you should not disassemble machine if you are not specialist. Contact Jura service center if your machine still under warranty.
Sep 25, 2013 | Jura Capresso Impressa S8 Coffee Maker,...
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
Aug 15, 2010 | Jura Capresso Impressa S8 Coffee Maker,...
No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Sep 13, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Jura Impressa S9 Steamer trips circuit breaker
Hi
There`s probably an leakage from the steamblock, and the water flows over the contacts. This will short circuit the machine. Contact your dealer or nearest servicepartner and they will fix it with a new water connector.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
846 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
