Question about Nintendo Wii Fit for Wii
My wii fit does not power on. we have rechargable batteries and we charged them overnight but still does not even blink the blue light. can you help?
  • simmba Dec 30, 2008
    I have the same thing. I used it for one day and all fine and went to use it again and it won't even power on the blue light won't come on so I call Nintendo and they have said to send it back : (
  • 32 Answers
I would contact nintendo for a replacement
Posted on Jun 07, 2009
The wii fit game is telling me to push the power button on the balance board with my foot. It blinks blue and that's it. The batteries are fine. So what do I do?
You need to sync the balance board with the Wii. It's easy to do and takes 10 seconds.
1) Start Wii Fit.
2) When it asks you to push the power button as you're describing, open the SD card slot on the front of the Wii and observe the red button.
3) Now, flip over the balance board. Remove the battery cover on the bottom of it, and press the red button beside the batteries, and the blue light should start to blink.
4) While the blue light on the balance board is still blinking, quickly press the red button on the Wii. If they are both blinking at the same time, they should be syncing to each other.
5) Your Wii Fit Balance Board should now be synced with your Wii! If it has been synced successfully, you will no longer need to sync it, and should now automatically connect when the button is pressed with your foot.
Apr 09, 2011 | Nintendo Wii Fit for Wii
Blue light on, battery won't charge, unit new 12/14/09
rechargeable batteries are definitely a better bet. I have used many Wii battery packs and chargers, none seem to last very long.
Jun 05, 2010 | Nyko Wii Fit Battery Pak for Nintendo Wii
I have a wii fit board, when you power it up, it
Had the same problem. It's a sync problem.
First, best to double check you have fresh batteries.
Next, turn the board upside down and remove the cover from the battery compartment.
Open the small hatch cover on the front of your console unit.
Now start wii fit from the disk menu item.
Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
While they are blinking, press the red button on the console (in the hatch compartment).
This should re-sync your board and the light stays lit.
Good luck.
Apr 07, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
Wii remotes blinks several times but doesn't work.
you see the little flap on the wii open it and the back of the wii remote then press both red buttons and wala good as new
Jul 21, 2009 | Nintendo Wii Console
Problem with wii fit rechargeable battery pack
make sure the battery charger is connected, and that the port connections are tight, other than that I would say you have a faulty charger.
Feb 06, 2009 | Nintendo Fit Battery Pack for Wii
Cant charge battery pack for wii fit balance board
You may want to send an email to customer.services@gem.co.uk. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
Jan 27, 2009 | Nintendo Rechargeable Battery Pack 3600mAH...
Power
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Battery Not Charging
I had this same problem and searched on the web for answers.... I could not find an answer; just complaints. I tried something that solved the problem! I noticed a greenish buildup on one of the three metal contacts on the battery. I wiped the green stuff off then the battery charged as normal.
The problem I was having (to ensure we have the same problem) was that the wii indicated the battery was out of power. I would put the remote in the charger and the indicator light would turn blue to show it was charging. A few seconds later the light would turn green to indicate it was done charging and was full. However, the battery was still empty. This would occur even if I left the remote in the charge overnight.
With the fix I listed above, the batteries now work as normal!
Aug 20, 2008 | Nyko Charge Station for Nintendo Wii
Wii remote will not work
Ok, glad it now works for you. Please rate this as fixed so it does not show up in the unsolved problems list.
Many thanks,
Mowcius
Aug 02, 2008 | Nintendo Wii Console
Nintendo Wii Fit for Wii Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
