Question about Zanussi ZHQ575 Electric Double Oven
Creda colonial oven
The cooling fan stays on all the time
  • Zanussi Master
  • 3,463 Answers
If it is the external fan that is staying on as opposed to the oven fan then it is probably a faulty thermostat that controls the cooling fan.
Posted on Dec 04, 2008
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
The fan runs when power to the cooker is on but the oven itself is not switched on.
Probably the cooling fan. There is a cabinet thermostat on most ovens these days (Especially wall or underbench models) to keep the cooling fan running after the cooking has finished and oven turned off. This fan will run for a few minutes to cool down the outside of the oven so it doesn't burn / discolour the surrounding cabinet or workbench. If the fan stays on all the time, I would say that the thermostat has probably jammed in the run or on position.
Mar 21, 2017 | Ovens
The cooling fan does not switch off after oven has cooled
function button or switch could be faulty
maybe that brand of fan forced oven
uses a thermostatic switch to that fan
Jul 03, 2016 | Ovens
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
Oven fan stays on
some ovens have a cooling fan that is controlled by a temp sensor, this will keep the fan running until the area where the sensor is cools. probably normal if it turns off after a while.
Jan 31, 2012 | Ovens
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
I have a ZOB580X single oven thats cooling fan never turns off and the only way to stop it is to switch off electrical supply.This is annoying as it screws up the clock every time I have to switch the oven...
Sounds like the safety stat is faulty or short circuit, causing the fan to stay on all the time, try disconnecting it, and see if that stope the fan from going, replace it if it does.
Nov 29, 2010 | Zanussi Ovens
Fan staying on
hello
Yes, this is normal. The fan stays on for a period of time to help cool the oven.
But if it stay too long then it means that there has been a problem on the wiring programming connected to the fan
thank you and thanks for using fixya.
Sep 29, 2010 | Whirlpool RBS275PD Electric Single Oven
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Zanussi ZHQ575 Electric Double Oven Logo
270 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
