Question about Dell 962 Photo All-In-One InkJet Printer
Print document w deleting status in que is frozen
Ive tried everything to erase/cancel print job but it remains frozen in que with deleting status. ??
    Guru:
  • 1,049 Answers
This happens periodically, for me restarting the machine has always fixed the issue. If it didn't for you I would suggest removing and reinstalling the printer.
Posted on Dec 09, 2008
Dell V715w all-in-one print job stuck in que
Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.
Good Luck
Aug 16, 2012 | Dell All-in-One Multifunctional (v715w)...
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
My printer has a job waiting that I can't cancel. I've tried everything including turning off the printer to erase the memory, and completely restarting my computer. Nothing will delete this print job
your job is stuck in the printer que, to cancel this go to control panel, open printer and other, right click on the printer icon, delete the job in que (are you sure you want to delete, yes)..........and you are done
May 10, 2009 | Office Equipment & Supplies
I attempted to print a 25 page document, with reverse pages. Only 9 pages printed. I cannot print anything now. and the message on the printer reads, DATA REMAINING. I have pushed every button...
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Apr 14, 2009 | Brother Office Equipment & Supplies
Can't print because document won't delete
You need to restart the print spooler service. Go to control panel>Administrative Tools>Services>there will be a list of programs. Find Print Spooler and right click on it. Stop service then restart. That will clear the print queue and allow you to start printing again..good luck let me know if you have any questions.
Rate this solution with 4 diamonds.
Mar 07, 2009 | Office Equipment & Supplies
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
482 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
