Motorola Mobility RAZR V3 Logo
nick casal Posted on Feb 07, 2007
Wont hold a charge
I just bought a razr phone off a friend and the battery wasn't holding a charge to i went to the verizon store and baught a bettery and it will only hold a full charge for about 4 hours...
Anonymous
Level 1:
  • Contributor 62 Answers
  • Posted on Feb 09, 2007
Anonymous
Contributor
Level 1:
Answers
62
Questions
6
Helped
45759
Points
67
Make sure you blue tooth is off. Also if you on the mobile internet, play your songs alot or have your screen brightness or screen saver or brightness on or up too high it will drain the battry also make sure something isn't on that should be off.
Cell phone battery loses charge as soon as i stop charging it
Surely you have a right to a refund or exchange if it is faulty. Check with your local Trading Standards or Consumer Protection. Tell the shop you are doing this, they might change their ideas.
Jul 27, 2017 • Cameras
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
1helpful
Unlock my motorola razr V3m cell phone
try all the defaults the last four digits of the phone number last programmed to the phone then standards defaults for all phones are 9999,1234,4321,0000,1111 if none are successful you will have to hook the phone to a charging station which is at the verizon wireless store I do believe they still have the software if they dont they will need to replace the phone either by upgrade to a verizon phone (two year contract) or activating an old phone you own or bought online elsewhere or got from a friend etc. or insuarnce claim which is fifty bucks and they give you the same model i have to say of all the razors thats the good one so if you do go with insuarnace i wouldnt accept anything else they might throw at you as comparible its not
Motorola razr v3 wont charge, the bettery is not that old the phone beeped to signal charge requred, plugged it in as usual but cant turn it back on.
If the charger is plugged in, the phone is hooked to it, and it still will not come on, I would think it's a charger or electrical outlet problem.  I think most phones will bypass the battery power if they are plugged into an outlet, so try another wall plug, and if that wasn't it, try a different charger.  If a different outlet and charger don't solve it, it may be time to take it to the store to be checked.
2answers
Wont charge
your charging port is loosely connected to *********** board. You need to go to a repair shop and get it fixed.
15helpful
3answers
Battery not holding a charge
Hi try this I had a new Blackberry which required charging every single day, take out battery and press and hold the on button on the phone for a min, then put battery back in and try charging again! mine is perfect now again.
Somebody told me that it's to do with static or something that builds up and flattens the batt.
Staying charged
I hate it when that happens! Batteries for cell phones these days are designed to only last about a year, and then the life will slowly decline from there. However, you seem to just have a faulty battery.
If you bought your phone through Verizon, they have a limited battery warranty program that lasts for one year. You can go to your nearest Verizon store and have them replace it, but make sure you bring your charger as well, they may want to just troubleshoot and test to make sure your charger isn't the problem.
If you are far from a Verizon store, or did not purchase your phone through them, you can purchase the batteries very cheap on ebay.. You wouldn't believe the markup on them!
2answers
Razr V3M Power-up/Black Screen
I ended up having to take my phone back to Verizon.  They replaced it with a brand new one because they were unable to find the problem.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
