Question about SanDisk Sansa m240 MP3 Player
No files but memory full, cannot acces files, pc cannot read file
Sansa m240 mp3 player and voice recorder, i bought as a souvenir during my visit to London. After three days of use in Kenya, i have a message on the screen -
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
How do i delete recordings on a sanDisk Sansa m240 MP3 player.
Manual for the m200 series, see:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
All about voice recordings in chapter 4, starting from page 22 of the manual.
On page 25 is the information how to delete recordings on the m240.
Nov 21, 2009 | SanDisk Sansa m240 MP3 Player
Can't get sansa scan disc clip mp3 player off record mode.
all right patti, call sandisc at 1-866-726-3475 they should be able to help ya ; )
Dec 29, 2008 | SanDisk Sansa m240 MP3 Player
I have a sandisk sansa m240 mp3 player i found but the screen is busted. I figured out how to do everything without the need of seeing what was on the screen, except how to record stuff.
This will probably be impossible without a screen, but here are the steps:
The Sansa Fuze has a built-in microphone allowing you to record your own voice, an
interview, or a speech.
To start voice recording, follow these steps:
1. Press the Home button to return to Main Menu.
2. Select Voice from the Main Menu.
3. Select Record Now.
4. To pause the recording, select Pause.
5. To stop the recording, select Stop.
6. Select Yes to save the recording.
7. Press the |<< button to return to the previous menu.
Dec 03, 2008 | SanDisk Sansa m240 MP3 Player
Sandisk Sansa M240 Screen Busted
Hard w/o screen, here are the steps:
Haw can I record and save? on SANSA of SanDisk
ok so go to menu record and then finish recording itll ask you if you want to
May 29, 2008 | SanDisk Sansa m240 MP3 Player
Voice recorder
Just plug the USB connection to your PC and delete the Record folder from your PC for the drive that the Sansa shows up on your PC.
Aug 16, 2007 | SanDisk Sansa m240 MP3 Player
New SanDisk Sansa m240 MP3 Player
Hey regan have u fixed it yet?? Mine is doing the same thing and it wont turn on at all well write back!! ~sam~
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
63 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
