Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold fridge not getting cold
I have had the fridge for about 5 years and it will not get cold it is running and blowing but not cold air
  • Anonymous Mar 16, 2009
    its blowin air but its not cold?
5 Suggested Answers
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
tomsat69
  • 214 Answers
SOURCE: Fridge Not Getting Cold
The only thing i can thing of is the start switch it may be burned out.It is located on the compressor.If your compressors running and there is no cold air in freezer part and fridge you may have a sealed system leak.Open the rear bottom panel while the fan is running and feel the compressor if it is hot and it is running you may need a repair person to come look at it.also forgot to say is if you have frost bult up in rear freezer panel that would indicate it is froze up and will need a manual defrost .After done that the defrost timer may need replaceing it is locatedaround the control and light area.hope i fixya :)
Posted on May 22, 2009
  • 6 Answers
SOURCE: (1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Posted on May 27, 2009
  • 66 Answers
SOURCE: too warm
First of all check to see if the compressor is running. If it's not running and you have no leakage of refrigerant. it is probably the start relay at fault, or the thermostat control is faulty. Check with a multimeter on ohms and check between common & start see what ohms it reads then check between common and run. see what that reads. then check between start and run, this should read what the other two read added together. if you have no readings then the compressor may be burnt out.
Posted on May 17, 2010
Testimonial: "thanks, i will try this out!"
Should the fan operate all the time in my refrigerator
Most of the time it runs only when the compressor is running. In other words compressor and fans will run together when the fridge thermostat ask for cold and stops together when thermostat is satisfied. In newer fridges some time inside fan (evaporator fan) might PERIODICALLY run without compressor to circulate little cool air to fridge compartment from freezer compartment.
Sep 30, 2014 | Whirlpool Refrigerators
I have a Whirlpool Gold refrigerator, model GB9SHDXP, about 2 and a half years old. It has a bottom freezer. Yesterday I noticed that the food in the top part were not as cold as usual. I came back...
ok,when you open the freezer door do you hear the fan blowing?all that happens is the freezer gets cold,a fan in the back wall of the freezer turns on and blows cold air up into the fridge section,a thermostat tells it when it's cold enough or it's getting warm then it will blow more air up top,if the freezer is working correctly then either the fan isn't working or the bottom freezer door was left open,warm air got sucked up into the air vents causing water droplets to be formed,then they freeze blocking the air vents with ice and now the cold air can't go into the fridge section.is there any ice on the ceiling of the freezer or frozen water droplets on the bags in the freezer?if so the door was left open.unplug the maction,and with a hair dryer blow the hot air into the holes on the back panel,keep doing this until you don't see any more water draining through the holes,turn it back on and see if the cold air is blowing up into the fridge.if the evap fan motor is bad the part number is W10128551 and it's around 25 to 30 dollars.you must of got the model number off of the book,it's not the full model number,check in the fridge section on the right hand wall near the ceiling and you should see a tag with the number on it.also down at the bottom kickplate,you can remove the kickplate and there should be a tech sheet tucked away in it,read it and it will tell you how to put the machine into defrost mode,if you can do this,instead of unplugging it if you have to melt it out with the hair dryer you can put it into defrost so the heater will come on and this will help you to defrost the vents quicker.let me know what you find and if you need any more help.good luck with your machine
Apr 12, 2011 | Whirlpool Gold GB9SHDXP
Whirlpool Gold GB2SHDXPS fridge/freezer has stopped working. It is not cold and food is thawing. The light in the fridge and the freezer is still on but it is not cooling.
can you hear a humming sound coming from the back of the refrigerator, if so that means your compressor is running, if you are hearing a buzz or clicking sound your compressor is trying to start, you may need a compressor. Some whirlpools have a 5 year sealed system warranty that would cover the repair.
Aug 22, 2010 | Whirlpool Gold GB2SHDXPS Stainless Steel
Whirlpool fridge not blowing cold air but freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
May 28, 2010 | Refrigerators
Too warm
May 17, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Dec 17, 2009 | Refrigerators
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Dec 15, 2009 | Refrigerators
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Whirlpool bottom freezer 5 years old everything freezes in the fridge
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Top shelf not cold whirlpool gold side/side
If you can check the back wall of the freezer where the evaporator is. If you notice that it is starting to ice up, (which by your description I'm sure you will), the most likely cause of your problem is lack of defrost. This can be caused by a couple of different things, ie. bad heater element, of limit switch, or the most common bad defrost timer. Hope this helps
Oct 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
229 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
