Question about Dell UltraSharp 1701FP 17" Flat Panel LCD Monitor
Everything has a yellow tinge.
Someone just gave me this Dell 1701 Flat Panel monitor. It works well, but everything is showing up really yellow. I tried going into the control panel and changing the color-that didn't work. I tried going into the menu on the monitor-that didn't work. Can anyone please help me?
    Novelist:
    Champion:
  • 202 Answers
Have you tried giving it a good tap on the side? Hey its worked before. Have you tried hooking it to another machine to verify "yellow." Was it yellow on your friends computer? How old is the monitor? Good Luck, Tim
Posted on Feb 08, 2007
I am using a compaq 1701 flat panel monitor. I installed windows Xp. The screen resolution is $4 bit color coz the driver is not installed. Looking for the driver for compaq 1701 flat panel monitor for...
The screen resolution and bit color is controlled by the video driver NOT by a driver for the monitor.
Install the correct video driver for your video card and you will be able to increase the screen resolution to over 1024 X 768 and bit color to at least 32 bits.
Jul 21, 2011 | HP Compaq 1701 17" Flat Panel LCD Monitor
The monitor is a Dell? UltaSharp 2007WFP 20.1 Inch Flat Panel Monitor. I Tried everything. different power cables, DVI cables, VGA cables, disconnecting everything and reconnecting. NOTHING WORKS. I even...
Not sure if this is your problem, but I have seen this with another Dell monitor on three separate occasions. The solution I found was to turn off at the wall power socket, unplug at the wall socket, plug back in, turn on at socket etc and everything was fine. Guess something hangs up somewhere.
Dec 08, 2010 | Dell Computers & Internet
Does this monitor have integrated speakers?
No HP Compaq 1701 17in. Flat Panel LCD dont have inbuilt speakers.Click here to see the specification.
If you like the post then please leave your comments and feedbacks
Thanks In Advance.
Oct 05, 2010 | HP Compaq 1701 17" Flat Panel LCD Monitor
My monitor is not showing red colors? how do i fix
There is a number of possible reasons why your monitor lost the red color. A good guess, however, is a broken cable or connector. Check the plug and socket of the cable for bend or broken pins. If everything looks OK, try to change for a different cable.
If the problem persists, a pin of the connector soldered to the PCB internally may be broken. This is an easy repair for a service technician but I really recommend you do not do it yourself.
Feb 05, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1900f monitor contrast/brightness problem
CLick start/run then type in dxdiag. Go to the display tab and click test dirext3d. There should be an 3d cube that comes up and spins around. After the cube leave cancel everything else and close dxdiag, Your problem should be solved for a pretty long time. If it happens again just follow the steps again.
Jun 11, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Compaq 1701 Flat Panel Monitor Powers Up but screen is blank
no when u power up the system press F8 key then u got safe mofde menu.
then go to enable vga mode then change resolutioin to 800 *600 or 1024*768
then apply and ok.
thats it.
Nov 11, 2008 | HP Compaq 1701 17" Flat Panel LCD Monitor
Problem with the InFocus IN1 Gaming Projector (when recieved) - No red, constant yellow tinge and constant lines.
It is because the xbox 360 is set to 60hz, change it to 50hz and it will be clear like it's meant to be. However, some 360 games are 60hz so for those games the quality is not good.
Aug 10, 2008 | InFocus IN72 Multimedia Projector
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
No Power LED and Nothing on the screen
Check your power supply to your screen cause it should at least show a amber light at the screen to show that there is power but no proper signal from the computer.
So below are step to check the power supply to your monitor. Assuming if you use a different monitor on your pc it works
1. Check your fuse both internal and external
2. check if power is receipted by the LCD
Mar 24, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell UltraSharp 1701FP 17" Flat Panel LCD Monitor Logo
344 people viewed this question
Clive
Clive
Alun Cox
