Question about Honeywell Heating & Cooling
My Honeywell RVL 3100 Thermostat does not shut off. I had several short circurts through bad installtion of wiring, now my thermostat does not shut off, heat stay on. Is my thermostat broken???
  • 49 Answers
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Posted on Oct 14, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
4-wire typical wiring of a thermostat is: Y (Yellow) G (Green) W (white) and R (red). Inspect the thermostat to see if it has a jumper from R1 to R2. If not, put your red wire on R2. On a 5-wire thermostat you may have a blue wire. This will go to the common terminal (usually C but sometimes B) check the inline fuse in the air handler to see if it has blown. Replace it only after wiring the thermostat correctly.
Posted on Dec 03, 2007
SOURCE: Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Posted on Oct 14, 2008
  • 252 Answers
SOURCE: need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Posted on May 16, 2009
johnsonr1
  • 91 Answers
SOURCE: Need to know wiring diagram for a weathertron
this link has a good diagram of the wiring. It should help you.
http://www.hvacmechanic.com/forums/hvacr/messages/17573.htm
Posted on Nov 05, 2009
Honeywell thermostat 3100 won't shut off
So you lower the set temp and the furnace wont shut off? If you take the thermostat off of the wired sub base does it shut off? If it shuts off, bad thermostat
Jan 05, 2018 | Honeywell Heating & Cooling
I just installed new thermostat model RTH6350, the problem I am having is the heater does not shut off once the desired temp is reached. Any suggestions?
if you turn the t stat to the off does it still run? look for a shorted wire. remove the t stat and check the wires for a short.does it work just hanging from the wall?
Feb 04, 2011 | Honeywell Programmable Thermostat Heater
Honeywell thermostat short and then went blank by mistake i short the thermostat with a wire and then became blank
Check the transformer in the air conditioner/heater. There should be a fuse on teh 24 volt side. Shut power off to the furnace. Locate and check the fuse. If there is no fuse, you probably destroyed the transformer.
Jul 17, 2010 | Honeywell Programmable Thermostat Heater
Iwire thermostat
RED TO RH, BLUE TO Y,YELLOW TO W GREEN TO G ON STAT GO DOWN IN YOUR FURNACE TO MAKE SURE ITS THE SAME ON THE BOARD ALSO SHUT POWER OFF WHEN WIRING IT SO U DONT SHORT ANYTHING OUT
Oct 18, 2009 | Honeywell Programmable Thermostat Heater
Installed my thermostat and the heat keeps climbing where did i go wrong? it is a honeywell Honeywell RTH221B Basic Programmable Thermostat
Make sure red wire is on R terminal, white wire is on W terminal. Also look for a short in the thermostat wire.
Oct 17, 2009 | Honeywell Electronic Programmable...
The digital display is not functioning
the thermostat could be bad. It may have gone bad on its own or due to a short in the supply wiring. Sometimes mice will chew on the wiring in the wall that leads to the thermostat. But I wouls change the thermostat. They do go bad. Make sure you turn the inside unit off first in case you accidently touch wires together. This will blow the transformer inside the unit if the fuse doesn't blow first. I even scene thermostats with fuses inside. So you may want to take the thermostat apart and check for inside fuse also.
Jun 18, 2009 | Honeywell Heating & Cooling
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
My Honeywell T87F Thermostat doesn't shut the A/C off when the temp in the room gets down to the Thermostat setting. I have it set on COOL and AUTO. I have to shut the A/C off; then later turn it back on...
Remove the thermostat and disconnect the r and y connection. If the A/C continues to run ya got a short in the wiring somewhere. If it shuts down then your tstat is hooped.
Jun 09, 2008 | Honeywell Heating & Cooling
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
213 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
