Question about Belkin (F5D7230-4) Router (587009)
Wireless can not communicate with my comp
I have full bars but no internet connection belkin wireless g router (mod # F5d7230-4) cant get internet via router to comp. router has all lights working/flashing but cannot get onto net.any help would b appreciated.
thanks sean
  • zzseanr Dec 05, 2008
    thanks for those tips. I have tried most of them and failed to get working. The laptop uses wireless and the desktop uses cable but neither gets any internet. Would the software need updating? haven't tried that one yet. the laptop picks up the router perfectly but the router seems that it doesn't pick up the internet via the Ethernet cable. Both the laptop and desktop uses xp pro .
    Thanks any more help would be appreciated
    Problem Solver:
  • 10 Answers
I'm assuming you are using windows XP or similar. You can check your tcp/ip protocols and local pc adaptor by 'pinging'. open the command prompt - 'start', 'all programs', 'accessories', 'command prompt'. Then type 'ping 127.0.0.1' without quotes. If there is 'no loss' of data, your pc is basically sound, as are the protocols.
Try reaching your router by typing 192.168.2.1 (or look on bottom of router or documentation for IP address). It may ask for user name and password which should be with documentation. You need to be able to reach your router before you can use the net.
If using a cable, check out your LAN by going to 'control panel', 'network connections', then find the LAN icon. Right click and left click on 'properties'. under the 'general' tab scroll to ' internet protocol tcp/ip'. double click on this. under the general tab make sure ip address and dns is obtained automatically.
If you're using the wireless capability (ie not network cable) right click on the wireless connection to 'view available networks'. try to connect to one. You may need a WEP/WPA etc password. You could try connecting a network cable from pc to router to see if it's a wireless problem or not.
In control panel look at 'internet options' and 'connections' tab. make sure it's set to use the right connection (eg mine just uses the LAN).
sorry if this is a bit muddled but there are many possibilities. Any more info on your setup would be helpful.
Posted on Dec 04, 2008
I have a belkin router but i cant find the security code for it to use it on a different computer
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Sep 05, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
Forgot passwrod for a belkin g wireless router - how do I recover it?
In order to find the wireless security password of your Belkin wireless router , please follow these steps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page.
3. In the left hand side, under the heading wireless click on Security
4. It will ask for a password to login, leave the password as blank and click on Submit, then you will be find the wireless security page where you can find your password.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 07, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
No wireless light, and no wireless signal detected
there is a possibilty that wirelss feature on ur router is not turned on as the wireless light is off.
U can open the gui(router page) of ur router by entering the default gateway on the browser address bar. First of all u would need to connect ur comp using the cable to ur router so that it could be connected to internet.
Go to command prompt and type ipconfig and press enter and it will give u the ip and default gateway of ur router.
U can type the same default gateway in the address bar of internet exploere and hit enter and it shud bring the router page.
Once u r on the router page u can check the wireless settings on to that and can alter them.
Jun 07, 2010 | Belkin Wireless-N Wireless Router with...
I'm trying to set up a new laptop to my belkin router
When you first setup a wireless router you need to connect the wireless router to the computer with a LAN cable.
Then you open a browser such as Microsoft Internet Explorer and on the address bar you type the IP configuration address of the wireless router eg. for Belkin wireless router it is http://192.168.2.1
Enter the default login name and password.
You should change the password and you should setup WAP or WAP2 encryption (WAP2 is the strongest encryption) and change the SSID and turn off SSID broadcast.
For further wireless protection enable MAC address filtering. The MAC address of the wireless card is entered in the router MAC address filter table, which allows only the wireless card with this MAC address to connect to the router.
The wireless card on the computer needs to be configured with the wireless router's settings. The LAN cable can be removed and the computer communicates wirelessly with the router.
Sep 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Buffalo wireless g router wont connect to old speedtouch modem
To fix this issue all you have to do is,
Confirm the model number & version of your router and check for firmware update
A It may be quiet difficult for you to do all this.please call toll free number"belkin"
.........Hope this is help full for you............
Apr 29, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
do you have encryption set on the wirless???
if so, you need to enter the encryption.
of not, uninstall the wireless from your computer and reinstall it. reconfigure the wireless setting.
Oct 30, 2008 | Belkin (F5D7230-4) Router (587009)
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin54g wireless router
its a belkin
its a static packet data router only so much info gets in before it can unload so it shuts down
get a streaming netgear router basically like a hooking direct to comp
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Program for belkin router
you don't require the disk...
co0nnect your belkin router with ethernet cable into the comp...
open internet explorer type an address as 192.168.2.1 it will take you to router config page..it will ask for a password leave it blank
click submit
click the Wizard link on the top menu bar.
For a UK ADSL connection, you will need to select PPPoA (Routing mode, for multiple PCs) even if you are only going to connect a single computer, then click the next button.
The next step is to enter your username and password that your service provider has provided you with. To try and ensure the password is entered correctly it must be entered twice. The VPI/VCI values of 0/38 are the correct ones for a BT Wholesale ADSL line. If you are using another telephone provider check the settings required. Click next again to continue to the next phase in the wizard.
This screen tells you what your Internet IP address is (the WAN IP), and you will note that the menu bar at the top of the page now shows the Internet Status as connected. For the review, there is really one bit of configuration left to do. During the course of reviewing hardware we tend to swap kit in and out several times, we generally prefer to run the routers on the same IP address (192.168.0.1). This is easily accomplished by clicking the LAN Settings link on the left hand menu of the Belkins web setup and altering the routers IP address.
The router is clever enough to alter the DHCP server IP ranges to match the new LAN IP address of the router. Once the changes were applied it took around a minute for the router to restart, during which time the wireless signal dropped, but once this reconnected the PC was assigned an IP address in the new range of 192.168.0.x.
Feb 16, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
Belkin (F5D7230-4) Router (587009) Logo
132 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
