Question about Toshiba Satellite A105 Notebook
MY TOSHIBA L315 NOTE BOOK DOESNT BOOTUP, GIVING MESSAGE MEDIA TEST FAILIURE, CHECK CABLE, FIXED A NEW HDD BUT NO ANSWER
    President:
  • 2,110 Answers
You have to restart your computer and pressed f2 once I was in the bios, then presse f9 to set up default settings in the bios and saved it. It will work....
Posted on Dec 04, 2008
I have a Toshiba NB305 and when I press the start button it goes to the Toshiba startup screen the reads PXE-E61 Media Test Failure, Check Cable. Is there any way to fix this??
Media test is either hdd, dvd or RAM issues. Make sure the cables are connected properly or remove each piece of hardware until the issue stops and replace the faulty part.
Sep 17, 2015 | Toshiba Computers & Internet
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Sep 18, 2009 | IBM NetVista PC Desktop
My Toshiba satlelite A105 will not boot up , comes up on screen black says pxe-e61: media test failure, check cable pxe-mof: exiting intel boot agent operating system not found
Go into SETUP (F2, DEL, Cntl-S or somesuch at boot time - or hold F1 key down and force and error and then change your BOOT order to CDROM, HDD. It is Currently NETWORK, CDROM, HDD or the like.
PXE is Network directed bootup, and your LAN connection is waiting or the proper code or instruction or server. You need to turn that off, and BIOS SETUP is where to do it ;-)
Hope that helps
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Toshia IDE #0 ERROR comes on the screen about 2 mins after starting then as follows is on the screen. .Intel (R) Boot Agent FE ver 1.10.PXE-E61 Media test failure check cable. PXE-MOF:Exiting Intel Boot...
This error is telling you that either one of three things have happened. 1. Your hdd cable has come loose or failed. 2. Your HDD has failed, or 3. the IDE controller on the motherboard has failed. You can check problems by trying a known good hdd in place of your old hdd. If bios sees it then it is the drive itself that is bad not the cable or controller. If it does not see the good hdd then try replacing the cable. If this fixes the problem then remove good drive & replace with your old hdd. Problem should be solved. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Toshiba (MK8034GSX) 80 GB IDE Hard Drive
PXE-E61: Media test failure, check cable
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
Boot
sounds like hard disk faliure, suggest getting a new hard disk or perhaps attempt a system reinstall. Its not the fan but the hard disk.
Geoff
Aug 28, 2008 | Tablets & eReaders
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite A105 Notebook Logo
131 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
