The programme switch on my tricity bendix washer dryer is broken with a full load inside and I cannot empty the water
    Sergeant:
  • 225 Answers
Two methods come to mind:
1/ You should be able to empty the water via the removable filter at the bottom of the machine. You'll need a suitable tray to catch it in, of course, and don't pull the filter completely out as there will be more than one trayful of water in there!
2/ Alternatively, you could insert a length of flexible tubing into the soap drawer, fiddle it down into the water and syphon it out that way. Removing the soap draw will probably make things easier. This method is much more controllable than the first one!
Hope this helps you a bit. If it does, a "Fixya" rating would be much appreciated. If it doesn't
help you, I'd be grateful if you didn't bother with a rating at present - they can't be increased later if I do manage to solve your problem! Just come back and tell me what you found. Cheers, D
Posted on Dec 04, 2008
My tricity bendix dryer TM 320W is heating up but it's takeing at least 3 full cycles to dry the clothes and the water tank is hardly ever full, whereas i had to empty it after ever few loads before. any...
check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
Aug 04, 2010 | Tricity Bendix TM310W Electric Dryer
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
May 09, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Dryers
I think the pump is full of lint, and is not able to pumpe the water from the bottom container to the container in the panel. Check that;)
Jan 03, 2008 | Tricity Bendix TM310W Electric Dryer
TUMBLE DRYER
Hi, It wont fill up when the full tank light is on because it thinks the tank is full. Remove the tank and feel down inside where the tank sits into the machine. You should feel the switch, it sounds like it is stuck down.
Jan 03, 2008 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
