Question about Philips 50P8341 50" Rear Projection Television
T.V. COMES ON FOR 10 - 20 MINUTES THEN GOES OFF
Hi my tv comes on for about 10-20 minutes then shuts off. I have to wait awhile to turn it back on but does the same thing again. The first time it happened i waited a couple of days then turned it on and it worked fine for about a week but started doing it again.I tried another plug-in in the house but same thing. House is about 40 years old and hear from girlfriend that shes had the same problem with 2 of her tv's in the last 6 years in this house upstairs and down, could they be related problems with power?.Or something completely different?.
    Scholar:
  • 168 Answers
Well based on your story it seems that your tv when get hot loose some of its contact. i beleive the symptom is cause by a loose solder (cold solder). this is normal especially tv's that are aging. it tends to loose its contact because most of the parts/components of this device are becoming hot when being operated. example of this are resistors, transistors, and ic's(integrated circuits). check the power supply circuits and the horizontal deflection circuits. because these two circuits are responsible for problem you are experiencing. also use a magnifying glass in inspecting the board. based on my experience looking alone without this glass is not enough. you need to magnify it, to see it clearly. but if you are not inclined with this kind of job, better bring it to a qualified technician. one more thing, i dont beleive that the house is related with this problem. otherwise all your equipment that are hooked up in it will do the same problem (on and off). i hope this help you! good luck!
Posted on Feb 14, 2007
Rca 46" tv shutting off then coming back on
Probably the power supply is failing.
Sep 02, 2017 | RCA Televison & Video
My 55ld520 screen goes black, turn off for short time comes back on but then goes black again.
Start simple by using different cables, whether they be HDMI, VGA or standard COAX cables. They could be losing the connection. Also, it's possible the power supply is wearing out and it gets too hot. You might want to simply try some spray air duster type thing to clear out any dust that can make it hot.
Sep 20, 2014 | LG 55LH40 55 in. LCD HDTV
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
Mar 30, 2014 | Envision L32W761 32 in. LCD TV
My 2008 dodge ram temp gauge goes from normal to high ,check gauge lite comes on in a few minutes temp gauge goes back to normal but heater will only blow cold air I,ll shut heater off wait a few minutes...
Souds like it's way low on coolant. The heater will blow cold air when the cooling system is so low that there is no water (coolant) running through the heater core. Then the thermostat opens, it trys to be normal but the system is low so it gets too hot in just a few minutes. If its that low, there must be a leak somwhere.
Nov 05, 2013 | 2008 Dodge Ram Pickup 1500
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
TV comes on, works for awhile - 15-20 minutes,
You probably have breaks in the soldering on the power supply board.
It can be fixed....but you need to be able to isolate and resolder the bad spots. Plus get the board in and out of the tv.
Mar 22, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
My tv shuts off after only two minutes
try using a master reset to fix this.
Sometimes after being used for awhile electronics tend to malfunction.
press and hold these buttons in this order....
power / volume up / channel down.
The tv should shut off after doing this.
Turn it back on manually.
This will reset the TVs internal memory chip.
I dont guarentee this as a permanent fix....but it worked for me.Good luck
Sep 19, 2009 | Sansui DTV2760 27" TV
Philips 50P8341 50" Rear Projection Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
