Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Screen goes dull at times
Hi
I have a Sony Bravia 50" 3 way rear projection tv...
My problem:
The screen goes dull then back to normal, it seems to happen when the picture goes darker and when it goes brighter again the tv seems to lag when trying to restore required brightness. I fear its the bulb ready to go. I also have to put settings to full brightness to get a decent image.
Also when i use HD in 1080 i get a ghost image of the picture appearing over the original image.
Can you please help??
And how much do you estimate repairs? Could i get parts and do it myself?
I bought this tv of a guy for £200 and hoped repairs would be reasonably priced.
Any help you provide I will be gratefull for,
Thanks
Regards
William
  • 505 Answers
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Posted on Dec 07, 2008
Have a 50fx48b Hitachi TV and screen flickers and then goes to small wavy horizontal line. smack tv and it goes back to normal.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | Hitachi 50FX48B 50" Rear Projection...
I have three blue-green spots on my Sony Bravia screen
Your light engine is failing and will only get worse. This is a very common issue with these models. The cost of the part is around $700. for the time involved Tigerdirect.com has a 60 inch Mitsubishi 1080p DLP TV for $799.00
Sep 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
56" sony rear projection picture problem
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 12, 2010 | Sony KP-57WS500 57" Rear Projection...
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a Sony Bravia 50 inch rear projection TV. The picture has darkened and I am up to the top end limit of of the brightness, sharpness and contrast. What has to be replaced to get the picture quailty...
check the flyback transformer turn a little bit clockwise the screen knobs this will help to increase a little bit brightness. beware of HV do not touch the wires, This is due to old CRT or FBT need replacement.
Jun 10, 2009 | Televison & Video
I have a sony bravia 50 inch rear projection tv. model KDFE50A12U .It has been working fine with no hints of a problem,yesterday when i switched it on the power light started to flash and the fan,bulb and...
i have a sony bravia 50 inch rear projection tv kdf 50e2000 the problem is it fail to switch on when it did it swicth on had black line cross the screen
Apr 01, 2009 | Sony Televison & Video
AV-56WP30 not allowing me to access convergence menu
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 02, 2009 | JVC AV-56WP30 56" Rear Projection...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
164 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
