Question about Canon MV600i Mini DV Digital Camcorder
No power Despite having charged the batteries and trying mains power there is no life at all in the camcorder. I have cleaned the contacts and replaced the backup battery (CR1616).It worked perfectly OK in both record and playback at Christmas. Urgent help required please going on holiday soon. Chutney
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Not much else you can do but take it to a service center,and borrow a cam
Posted on Sep 27, 2007
SOURCE:
Charged batteries but wont turn on
hi,
check for possible corrosion on the battery contact, then power on key for sticky, use CRC spry to clean.
Jul 18, 2015 | Sony Cyber-shot DSC-HX1 Digital Camera
I have a sony hdv 1080i camcorder. it works on mains power but will not work from a fully charged battery. Can anyone help suggest a solution?
Are these new batteries or old ones? If they are old it is possible that they will show as full but not have enough current to operate the device. If the batteries are over three years old or have been charged more that 300 times that is a distinct possibility. Also check the battery contacts on the device to make sure that they are not dirty. Clean with a pencil eraser.
Jan 10, 2015 | Sony HDR-FX7 Digital HDV 1080i High...
My JVC GRD225 camcorder will not power on or charge even when the mains power cable is plugged in. No life what-so-ever.
Well all i like to say that first of all you can try changing the battery of your camcorder, this is the most common problem of not charging error..........
Good Luck!!
Thanks for using FixYa!!
Jul 27, 2010 | JVC GR-D225 Mini DV Digital Camcorder
My tomtom doesn't hold a charge and it has touble finding a location.
First thing to check is are they actually being charged ALL the time you have them on charge. A couple of Ones which I've repaired myself had problems with the soldered joints for the connector on the printed circuit board. When the plug was wiggled about it made an intermittent connection and wasn't charging all the time.
Connect your charger and try wiggling the plug gently.
also your contacts may require cleaning this can be ddone by spraying "Switch Cleaning Lubricant" onto the contacts on the base of the unit.
Definitely make sure its actually charging, usually this can be done through the menus to see satellites and the battery life indicator. It will show if its charging or not...Electronic cleaner or even rubbing alcohol on a q-tip can work on the terminals. Making sure the charger is unplugged and the device battery is drained before cleaning should be a priority...
How old is the device. Despite what Garmin and Tomtom tell you Lithium Ion while being a good technology has its limitations, and the main limitation is its overall life span in combination with how fast it goes from what seems to be a good battery to something that barely holds a charge for a few minutes...
Its a standard lithium ion battery inside. It can be replaced relatively inexpensively. However getting too it can be tricky and I'd suggest reading up on battery replacement before attempting. Also for future reference keeping a lithium ion battery fully charged all the time will keep it lasting longer unlike older batteries that would develop a "memory" and benefit from being drained completely from time to time... the trouble finding location could possibly be attributed to the amount of power it gets from the batteries.
Jul 05, 2010 | GPS
DCR-TRV30 Internal clock battery is end of life. It will not charge overnight or hold date/time set information between main battery changes. There is no replacement information in the user manual. Where...
This small back-up battery on my Sony is under the main big power battery, it is like a large screw under the main power pack, I just turn that screw and the little round lid comes off to get to the little silver flat back-up one.
They are readily available from most good camera shops like Jesops for around £12 to £15 each.
May 23, 2010 | Sony Handycam DCR-TRV30 Mini DV Digital...
Battery pack use
I have a similar problem. My MV650i works from the mains power but not from the battery even though I have tried new battery packs.
Feb 01, 2009 | Canon MV650i Mini DV Digital Camcorder
JVC EVERIO HYBRID GZ-MG330 Battery error?
I bought a replacement data battery BN-VF-808U from Digicowfish through Amazon.com. (?made by PomerPower).
It fits nciely to my JVC Everio GZ-MG330 which uses a BN-VF808U data battery. However, JVC gives a screen message:Communicating Error.
Now I have solved my Communication Error by using a jumper cable provided with the replacement battery BN-VF808U to connect the attached replacement battery to the camcorder. There is a DC input socket on the camcorder. There is also a DC input socket on the replacement battery for direct connection.
JZC
Aug 06, 2008 | Video Cameras
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Camcorder problems
clean contacts on battery and camera if the battery is charging properly then get a new battery and charge this one and if same resaults then have camcorder repaired check if you have got power using power lead from mains adapter it maybe contacts problem with unit and external power. hope this has helped
Mar 29, 2007 | JVC GR-D350 Mini DV Digital Camcorder
Canon MV600i Mini DV Digital Camcorder Logo
71 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
