Question about Kodak Professional 8500 Thermal Printer
Paper jam i bin geting a paper jam on my kodak 8500 every time it passes through 3 times then james help help help
  • Anonymous Apr 29, 2009
    Kodak Professional 8500 Digital Photo Printer
    paper passes through two times then stops and screen says 'paper jam'
  • Anonymous Mar 31, 2014
    Cover in back of printer was put in backwards and is jamed. How do I get it out.
    President:
  • 2,110 Answers
It takes a little bit of disarming because you've got to clean the rubber rolls that "pull" the paper, a pair of grey rubbers almost cilindrical with a flat side located over the top of the paper, and happens that you cant clean them properly if you dont disarm the printer. These rubbers must mantain their "stickyness" to be able to pull the paper properly and with the use they become dirty.
That is the problem, so take your screwdriver and some isopropilic alcohol and ...........good luck.
Posted on Dec 04, 2008
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
Paper jam on my ESP3 printer. How do I get the
Go to www.kodak.com/go/itg and select all in one printers and then paper jam as your problem. they will give you step by step instructions to resolve the issue. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printer for you free of cost as all the esp-3 printers are in warranty as of now.
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam
Yes, put it in the box and take it back, and don't look back. A paper jam is the least of it's problems. Wait till you keep track of the ink you use: 4 4X6 color pictures, and 85 black printed pages before you have to replace the inks. I know , I have one, 3 printheads replaced, and recently Kodak send a rebuilt printer. Kodak has big problems with this.
Get an HP printer.
May 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Apr 01, 2009 | Kodak ESP 5 Printer
Xerox 7750 - Jaming in fuser
Solution 1: There is probably a very small piece of paper caught in the fuser, remove it from the machine if you can and try manually feeding paper through it.
Solution 2: Try different paper. The paper may be too weak to pass through the hot fuser, and this doesn't matter you are always using the same paper company, sometimes they change their suppliers.
Follow the link below and good luck.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(20159)
Also check this link if there is a grinding noise as well as the jam.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(21995)
Dec 04, 2008 | Xerox Phaser 7750DN Laser Printer
Paper jam
Are you sure you have the correct size paper?
Also check and make sure the exit rollers are turning, if not then there is a broken gear in hte fuser
Jul 23, 2008 | Office Equipment & Supplies
Printerjam
A paper jam error message will appear if the printhead is not correctly installed. Try removing and reinstalling the printhead again, but make sure it snaps into place. Try loading a sheet of plain paper and press at the same time copy+cancel; hold them down until the printer feeds the paper. The paper will go through the rollers and come out blank.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Running NCR on canon IR 8500
Hello Visionsp, NCR paper is special in so many ways (uhg).First of all is is typically thinner than regular 20# bond paper. Second,each sheet is chemically "married" to the other as there are ink beads on the back of one sheet that are activated by the unique beads on the face of the second sheet so to some degree they are manufactured to be mated together. So unless your paper feed system is @100% then the sheets (2 or 3 sheet NCR) are more difficult to seperate and are inclined to feed two sheets at once. THE BIGGIE is this. Consider the fact that in order to produce the carbon copy image that is being transferred from the top sheet to the pages below it requires pressure from from the pen. Your IR 8500 (and all modern copiers) has a section of the copier called the fuser.It uses extreme heat and pressure to bond the powdered carbon based toner to the paper by passing your normal copies between two heated and tightly gripped rollers, kinda like using an iron with extreme force. When the NCR paper passes through the fuser the exteme heat and "pressure" break the chemical ink beads on the NCR paper and begin to leave a layer of the very same chemical ink on the rollers as they pass thru.But instead of only trace amounts of carbon copy image (as would be reproduced by a customers signature on to the next sheet ) the entire NCR sheet is being heated and mashed and a large amount of the chemical ink is being activated rightat the point of maximum heat and pressure. Not only is this sticky as *&%$ ,but it leaves a residue on the fuser rollers (since there is no paper to transfer the beads to) and the rollers build up with ......basically ink. So at some point the copies going through the fuser will rather wrap around the rollers or cause "accordion" jams because the telon coated rollers are no longer coated with non stick teflon but are coated with tacky gunk. The only workaround for this is to run small runs of the NCR paper at a time, then run regular white paper for a while which will remove the buildup and then another quick run of NCR and so on. I have worked on Canon,Toshiba,Ricoh,Savin and Kodak copiers.The results are the same.NCR paper is not designed for regular copiers as they all use the same type fuser system. A press or a RISOGRAGH are the only reliable systems to run NCR paper. I wish I had better news.NOTE: even the workaround I have provided,which can work, does not eliminate the possibility of ruining the fuser rollers beyond repair. good Luck...............SPINAL
Feb 09, 2008 | Office Equipment & Supplies
Paper jam NOT
Try this, remove all paper and bins.
then get alcohol and a clean cloth, clean all rollers and tires. You will get a lot of black dirt and stuff off after cleaning really well try, if it works for a while then yhat was your problem,if it is only temporary then tires will need replacing.
Oct 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
Kodak Professional 8500 Thermal Printer Logo
400 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
