Question about Sun UG-MON-FP (White) 18.1 in. Flat Panel LCD Monitor
Sun x7144A / GH19PS 19 LCD Turns off after several minutes
Works perfectly for 5 mis, then switchs off, but pressing front button makes it go a bit longer until it wont turn on.
Opened up with a 1 inch wide paint scraper, many screws, and removed a higher quality power board. Tough ******, well screwed together. Used LCR meter to check electrolitic caps in circuit and saw nothing too far out of spec. CapXon brand seem better than many. Nothing looked burnt/unusual and joints looked very good. What should I look at next?
Could it be the blue PTC's? And if so how to test?
Anyway please add this monitor to the 'list'
  • Canberra1 Jan 16, 2009
    Ive no Idea which chip this is micon novatec nt68f63 .
    Google says SAMSUNG LCD 510n and 710n have this Microcontroller and allude that it may be a processor firmware issue - and a jig and reprogramming - gee these Brazilians are good.
    Usually reseating and checking Vcc on the chip is done before replacing.
    I also wonder if there is some hold in the front buttons master reset
    that resets to factory defaults - so fixing settings that got corrupted
    The busy lots of 120 pins processor is
    The EEPROM with Sticker is
    28.9.2004 Q
    (AML) (E08)
    Electro Cans 2 * 100uF 16V
    4 * 10uF 16 V
    Board Marked underneath
    Logic Board
    400024135 SDMA 00179
    AF19B NORMAL S1.0
    Top of Logic Board
    Model MB17AS/BS_NB19AS/BS
    Code No BN41-00313B
    Tinplate stamped
    Power Inverter Board
    REV A
DEar friend you problem is the micon novatec nt68f63 only.You need to change it! Can you send for me the number in label in processor? This number is the checksum of this and I have lost this label best regards.
Aristides Pandelis
aripandelis at
Posted on Jan 10, 2009
Sun Roof mis operation
Try when closing, hold button for 5 seconds when already closed and attempt to open. If it opens all of the way. Keep button depressed and hold button when it gets all of the way open,hol for 5 additional second and repeat this open and closed. This will tell the body sunroof ecu Walt the travel limits are
Apr 06, 2014 | 2003 Toyota Celica
My AOpen 19" LCD Flat Screen Monitor (Model F2915) is like new and works perfectly except for one thing. The push button power switch located on the top of the monitor has broken off and fallen insid
Certainly, if you jumper the connections to see which ones turn the monitor on or off, then you can go to an electrical supply place and get a micro switch and wire it in in place of the power button, or perhaps find a type that is flat that the power button can press. What you need to determine is if it is a push-on, push -off type switch, which always stays on or off depending on position or if it is a momentary interrupt switch where the button pressed momentarily turns it on and then releases and a second press connects the circuit to turn it off. You can do this by testing with your jumper wire, attach it and if the monitor stays on when you remove it, then goes off when you attach it again, you need the second type switch, if it goes off when removed, you need the always-on always -off first type switch. .
Mar 07, 2012 | AOpen F90GS 19 inch Monitor
It makes a blue screen every 20 minutes and says anti theft alert so i unplug it for about 5 minutes and then it works and does it again
To turn off anti-theft mode:
1) Turn off the monitor
2) Press and hold the menu button
3) Turn on the monitor
Release all the buttons
that should disable the anti theft mode
Mar 13, 2011 | Acer G185HAb 19" LCD Monitor
I bought my son a 19" philips tv model # 19pfl340d/ order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Hello how to adjust brightness on an ACER 19" LCD monitor? thank you Kurt
1. Press the MENU key.
2. Press the < or > key to select the BRIGHTNESS icon from the menu (looks like a little sun).
3. Press the MENU button again to enter the BRIGHTNESS menu.
4. Use < or > to select appropriate brightness.
5. Press MENU button to exit.
5. To exit - select the EXIT function from the menu and press MENU button again.
Apr 01, 2009 | Acer X193W LCD Monitor
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
Zoom button does not work
Go get some Electronic Contact cleaner and on the Side of the Toggle switch spay a little bit in the front and rear of the switch ,Make sure the Battery is out and spray the rocker up underneath to get to the Tact switch,Rock the rocker back and forth several times to clean the switches,The Contact clear will dry quickly,After dueing this let dry for 5 Min put batt and try it good luck Let me know if this works ttech
Jul 24, 2007 | Sony Handycam CCD-TRV16 Camcorder
Sun UG-MON-FP (White) 18.1 in. Flat Panel LCD Monitor Logo
1,893 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
