Question about Car Audio & Video
Amp neon lights wont turn off
I have a hifonix amp. when the amp is turned on the lights on the top light up along with the power light. when the power is turned off in my truck, the lights on the top are still on. Can you help me with this problem?
There are two types of power that feed your amplifier. There is a constant power that connects directly to the battery and there's a remote power that usually connects to the remote power output of your deck. Some decks do not have the remote power output, but they have a power antenna output that works just as well.
The remote power is what enables the amplifier to turn off when the car's power turns off.
Either way, it sounds like you have the remote power input on the amp connected to your constant power source.
That would prevent the light from turning off with the car.
If you don't have a remote power or power antenna output on your deck, I would invest in a new one.
However, it is relatively easy to find a remote and a constant power source in your fuse box.
Purchase a fuse tap for a few cents and connect the remote power input on the amp to a power source in the fuse box that turns on and off with the ignition.
Some of the power sources you can find in your fuse box that go on and off with the ignition may be labeled something similar to the following:
ignition, power windows, radio, accessory, etc.
The constant power sources in your fuse box are the ones that don't power off with the car, such as the dome/interior light, power locks, battery, etc.
I hope that some of this helps out a little.
Posted on Dec 04, 2008
Brake light dodge neon 2002
Check the brake fuse in your dash's fusebox. Since the turns work, you know the bulbs are good, unless your Neon has separate brake lights. If the fuse is good, bulbs are good, then check for power at the brake light switch on the upper portion of the brake pedal. Should have 12 volts there all the time. Use a testlight or voltmeter to check. Good luck.
Nov 19, 2011 | 2002 Dodge Neon
My kenwood amp wont turn on all the way i just hooked it up to my truck. the blue lights and the fan come on but the red light wont come on to power my subs
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL DOES NOT POWER UP, VERIFY THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN TRY AGAIN. IF STILL NOT POWERED UP, MEASURE THE REMOTE WIRE VOLTAGE TO INSURE THAT IT IS NOT LOWER THAN 11 VOLTS. IF YOU CANNOT MEASURE IT, THEN DISCONNECT THE REMOTE LEAD FROM THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER WIRE FROM THE POSITIVE POWER TERMINAL TO THE AMPS REMOTE TERMINAL WHICH WILL FORCE IT TO TURN ON. IF IS STILL DOES NOT POWER UP, THEN IT WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 20, 2009 | Kenwood KAC-7203 Car Amp
Tv wont turn on but acts like it is
either a relay or power supply or high voltage transformer is bad. You can test any of these with an ohmmeter and a voltmeter or better yet a multi-meter. Then if low or no resistance, it is bad.
Oct 14, 2009 | Hitachi 55VS69 55" Projection HDTV
The head lights on my 1995 dodge neon wont turn on
I suggest that you have just answered you own questtion!
Regards,DT
Aug 27, 2009 | 1995 Dodge Neon
Have a dodge neon 2000, the lights will turn on
starter may be bad have someone turn the key at the same time you tap the starter with a hammer it is right in front
Jun 08, 2009 | 2002 Dodge Neon
1995 Dodge Neon
the daytime runnling light module is in the dash under cigarette lighter i got my module for 10 bucks at a junk yard
Aug 15, 2008 | 1998 Dodge Neon
1995 Dodge Neon
you have an electrical short somewhere....id get it to a dealer or other expert and have it fised beofre it burns something up
Jul 25, 2008 | 2005 Dodge Neon
Kenwood KAC-749S
Try to take out the lights that you put in yourself, but do it carefully, as you might have bridged out the power connectors that go through to your subs.
Mar 28, 2007 | Kenwood KAC-749S Car Audio Amplifier
Car Audio & Video Logo
343 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
