Question about RCA HD52W59 HDTV Projection Television
My HDTV shuts off periodically.
The TV will shut off and when I push the on button on the remote it will cut on but video screen cuts on the TV cuts off
  • RCA Master
  • 5,138 Answers
You have bad capacitors 3 of them cp150 2200uf 16v and the other 2 are in same circuit 220uf 35v they are green with gold writing on them.
Posted on Dec 04, 2008
Won't completely shut off
Do you have a separate Cable Box? It sounds like you are shutting off the signal to the TV and may have to push a 'TV' button the remote then the 'off' button to actually shut down the TV.
Nov 21, 2013 | PixiModo Reflection 15M 15-Inch Digital...
The picture is cut off on all sides, and we have tried every button on the remote control - still no solution... Help!
U have the tv original wright?Yes?U tries push the VIEWMODE button pushes it couple times and pick Side Bar, S.Stretch, ZOOM, Stretch to pick the picture on screen that fit ur tv screen u like.
Aug 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I make the screen smaller - the heads are all cut off on the screen
Find the button on the remote crontrol said,VIEWMODE,push the button change the aspect view mode.Pick diffrence aspect put in on S.Stretch view mode,best mode to fit,for the tv screen.
Jul 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
When i push the on button tv turns on or makes clicking sound timmer light flashes and turn off. another thing is when i push device on remote or tv the tv turns off or screen turns blue then shuts off
I would start by pressing the reset button on the front of the screen. After you are able to turn the tv on, press menu the 2470 then press enter on the remote to reset the tv. This might fix your problem. If not suspect the E2P, and if that doesn't work your DM is faulty and needs replaced.
Jul 06, 2010 | Mitsubishi WD73727 73" HDTV
Tv cuts off and on no picture or sound
Most TV shut downs like this are HEAT related.Try increased cooling with a fan blowing into it to test this on yours.If it works leave the fan running or repair with a nice little but strong computer fan placed behind the unit..
Aug 17, 2009 | LG 32LG30 32 in. LCD HDTV
My tv picture cuts off at the top, losing scores or tops of heads
Have you tried the "Aspect" button below the menu keys of the remote? Try "Full" Aspect and see if this improves things for you.
Hope this helps.
Apr 08, 2009 | JVC LT-42X688 42 in. LCD HDTV
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Jul 11, 2008 | Televison & Video
Tv loses power
the processor on this et will shut this set down for number of reasons. a technician should be albel to read error codes form the processor to help deterine whatt is cause the shutdown
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power cuts out on PT-53WX42
unplug tv check the fuse and the rating on it,.see if filament inside is burnt
Oct 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
