Question about Amana NAV5800A Top Load Washer
Washer continues to spin slow in the last spin cycle.
My top loader is an Amana LW2503W model but is a top loader and should work about the same. My question; is this a belt problem or do I have a machine that has a motor with a hi/lo switch on it. Previously when it was working correctly it was as if the motor speeded after most of the water was spun out and the spin cycle was about twice as fast as it was at initial start up of the spin cycle. It currently spins slow the entire cycle and leaves the clothes with far too much water in them. To get the water out of the clothes I currently have to run the clothes through the final spin cycle twice before they are dry enough to put in the Dryer.
  • Anonymous Jan 07, 2008
    cannot remove water pump to replace belt
  • drywall boy Feb 24, 2008
    I have a Whirpool LSQ8511KQ washer that doesn't spin fast enough to get all the clothes dried out. I have all ready replaced the lid switch becouse of it not working properly and pulled apart the water pump to see if anything could be clogging it but it appeared to be fine, no lint or anything. Any advise would be helpfull. Thanks
    President:
  • 878 Answers
Red Ryder, the motor is 1 speed on this model. A couple of things to check; one would be the belt. Look for shavings, cracks or if it's shiney, could be worn. If your p number is p1118410ww, looks like you have 2 belts, agitate and spin and pump. Pump-R0606507, spin-R0606539. Check the pulley, make sure it is not binding, lube it up, and check the pump, something might be binding there. As long as you don't have a grinding, howling noise during spin the bearing should be good. Catriver..post back.
Posted on Feb 21, 2007
Amana washer making a grinding noise when draining and getting ready to spin Model # NAH6800AWW
hi,
sounds like the couplers going, if its a traditional top loader, the coupler is in between the motor and the transmission and are meant to shear off to protect the machine from damage, overloading. they dont last forever. once you get the motor off the part is right there..
if its a front loader check the belt teeth.
jm
Jul 20, 2017 | Amana Washing Machines
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle doesnt work
Hi.
Here a general troubleshooting for no spin problems : If you have no spin there may be different reasons behind the problem. Before advancing to
With top loaders you need to add to the list problems related to motor and transmission. Such problems will be at the end of the troubleshooting list, right before inspecting the electronic control.
With this model the more common failures are concerning drain system, lid switch and pressure switch.
Here parts.
Regards.
Ginko.
Jan 09, 2011 | Amana DLW330RA Top Load Washer
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
Won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Mar 11, 2009 | Amana NAV5800A Top Load Washer
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
Amana NAV5800A Top Load Washer Logo
543 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
