Question about Xerox Phaser 7750DN Laser Printer
Xerox 7750 - Jaming in fuser
Everytime we print the paper gets jammed in the fuser.
    Scholar:
  • 49 Answers
Solution 1: There is probably a very small piece of paper caught in the fuser, remove it from the machine if you can and try manually feeding paper through it.
Solution 2: Try different paper. The paper may be too weak to pass through the hot fuser, and this doesn't matter you are always using the same paper company, sometimes they change their suppliers.
Follow the link below and good luck.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(20159)
Also check this link if there is a grinding noise as well as the jam.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(21995)
Posted on Mar 30, 2009
  • Niallbt Mar 30, 2009
    Please copy and paste these links directly into your address field as the " ) " is not part of the link
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Phaser 7750 Not Printing, No Error codes, Fuser Wont Warm Up, Wont Detect Open Trays or Doors
It sounds like one of the cover or tray sensors is not working correctly. Check the actuator on the fuser cover, sometimes these break off so the printer thinks the cover is still open. If that seems ok and you have a lower tray deck unplug it to eliminate them as the cause.
Apr 07, 2017 | Xerox Phaser 7750 Laser Printer
I have a Xerox 3450 printer. Everytime I print a paper jam occurs. I fix the paper jam and print and it happens again.
i think you have to replace the fuser assembly. 126e02480 is the part number it will
hope that it will help you
Feb 06, 2013 | Xerox Corporation Phaser 3450 Laser...
I have a 7750 xerox printer. paper keep wraping around the fuser roller and jamming. the fuser has been used for only a short time. Is this a damage unit and need to be replaced or is there something I...
Hello sir; Try to move out fuser unit, check the fingers against the fuser rollers, does it build up toner on the finger tip if it does, clean it up otherwise replace it.
Nov 06, 2009 | Xerox Phaser 7750DN Laser Printer
I have a xerox phaser 2135, the paper get jam at the fuser everytime i try to print. please help.
sounds like a bad paper feed sensor, take it in for repair or have it serviced, cause if the sensor is Bad, You wont be able to fix it w/o a tech's help.
Jul 21, 2009 | Office Equipment & Supplies
Paper keeps jaming!
Print a test page, then when it jams, notice if the paper made it's way in to fuser (toward the back of the unit. If it got that far, your fuser may be bad.
Let me know.
Nov 22, 2008 | Minolta magicolor 2400W Laser Printer
Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
May 06, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 7300N paper jam
What code is comming up with the jam? That would help me narrow it down for you.
Apr 05, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
574 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
